2020-07-11, 20:04
Hi all,
I am trying (and losing patience) with installing Kodi to my non-jailbroken iPhone X running ios 13.5.
I have tried AltStore but the app crashes after selecting ok on the 1st dialogue box. I have since read that altstore is not support yet. I am also reading that it might be possible to install if I use the latest BETA version of AltStore. Can anyone confirm and/or point me in the right direction.
I thought it might be because of some bad settings files from an on old (Very old) version that I used to install via the Xcode method. I stopped doing it that way because I got bored of having to reinstall every 7 days! I have tried to install fileza/ifile/ifunbox to find and delete those old files but not having any luck on getting those loaded either.
I also tried Just loading the ipa file (which I converted from the deb file) using iFunBox but that didn’t work either.
Is anyone able to help me get a working Kodi on my iOS device without Jailbreaking?
Thanks in advance,
Xsy
Thanks in advance,
Xsy
