  • 10
  • 11
  • 12(current)
  • 13
  • 14
  • 439
(2020-08-11, 09:11)AchillesPunks Wrote:
(2020-08-11, 08:17)spinecho Wrote: @AchillesPunks sorry, very stupid question... How do I download these from GitHub?
Front page.
Thanks... thought had to download a file directly from GitHub!
Front page.
Let me know what you think.
Titan Bingie Mod
why I don't have "layout for widget" in the customization of widgets? Huh
(2020-08-11, 11:55)shkop Wrote: why I don't have "layout for widget" in the customization of widgets? Huh
You need to disable fixed focus widget in vertical scrolling. Then you will have the layout option.
Titan Bingie Mod
thank you for your reply, if I disable I end up with this:
(2020-08-11, 12:30)shkop Wrote: thank you for your reply, if I disable I end up with this:
Disable go skin shortcut change view then enable fixed focus frame
Titan Bingie Mod
i am lost lol can you take a screenshot please?
(2020-08-11, 12:58)shkop Wrote: i am lost lol can you take a screenshot please?
Titan Bingie Mod
I did what you said but still the same problem, I must have been wrong somewhere Confused
(2020-08-11, 13:37)shkop Wrote: I did what you said but still the same problem, I must have been wrong somewhere Confused
1. Disable fixed focus and amend your widget layout (I believe you already did this!)
2. Re-enable fixed focus.
ohh okk I did not understand correctly, sorry thank you for your help Big Grin
the clearlogo has shrunk since the update ?
(2020-08-11, 09:11)AchillesPunks Wrote: Front page.
Hi, Just downloaded the new update and installed/updated it.
Cannot see any changes to version 1 - ClearLogo still small and my UK ratings are the same monochromatic as original version.
@AchillesPunks  Great Idea for Highlighted Widgets , I love it , some thoughts , This option should be in all widgets rows ,  people can select for there taste . Secondly Highlighted widget doesn't have Focus means borders ( When they are not highlighted ) , Thirdly Clear Logos for widgets get small " Spinecho & shkpo " are rightly saying  Logos are small now. Highlighted widgets smoothness is a little issue .
https://i.postimg.cc/zG2vLJKh/image.png
See Logo Size
https://i.postimg.cc/SKb5f96b/image.png
and Rating Certificate back to default
https://i.postimg.cc/MKm23dGK/image.png
(2020-08-11, 04:12)AchillesPunks Wrote: I added the Highlight Layout to GitHub for testing. You cannot use the Highlight layout for the Home Layout. It must be used inside Configure Shortcuts/Home/Widgets/3rd Widget. Set layout to Highlight. You must enable set 3rd widget inside home setting. Trailers do not work properly yet. Still trying to figure this out.
Sorry, I must be a real thicko - but I cannot get this to work. :-(
  • 10
  • 11
  • 12(current)
  • 13
  • 14
  • 439
