  • 54
  • 55
  • 56(current)
  • 57
  • 58
  • 442
(2020-09-18, 22:46)AchillesPunks Wrote:
(2020-09-18, 21:32)cscott1 Wrote:
(2020-09-18, 21:25)HugoL Wrote: View_525_Bingie_Episodes.xml.  You're totally fine to just replace this with the original. I made some minor adjustments in there which you'd lose but they only affect UK MPAA Icons so you'd have nothing to worry about.
Thank you
I sent you a private message. Just send me your email, and I'll give you the episode view with the landscape turned off
Thanks I got it and sent you my email
Running Matrix Titan Bingie Mod skin on Nvidia Shield to Insignia 58in 4k TV in living room. Same setup on Xiaomi Mi boxes in my bedroom and home gym. Same setup in camper with a 24in tv, Google Pixel 7 Android 13 cell phone. Kodi and Plex Server Dell Inspirion 5575 Ryzen 5 HTPC Windows 10 with 5TB external HDD
(2020-09-18, 08:24)HugoL Wrote:
(2020-09-18, 04:13)SuperSlo Wrote:
(2020-09-17, 10:34)HugoL Wrote: I never noticed the tags because I don’t use them. I’ll take a look but what’s up with the rest of your view??
Your Aspect ratio looks all wrong and where’s all your text too? Also your spotlight looks really small.
The lack of text was just the spot my widget was at the time I took the screen shot. It's my next episodes widget so usually doesn't tend to have that much information to show. Also, I use different layouts throughout my homescreen for my IPTV and Radio staions so that might have something to do with the aspect ratio.
http://imgur.com/gallery/R7Piofu
That's better. Still a bit strange you were missing the title in your previous picture though. Also, looks like you're using 3:2 aspect ratio making everything really stretched vertically.
Oh that aspect ratio 😂
Yeah I just used / to jumped into window mode to take the screenshot, so depending on whatever I was doing on my PC earlier that was the window size of Kodi at the time. Pretty sure the text missing was because I was in between widgets.
(2020-09-18, 21:32)cscott1 Wrote: Thank you
Email has been sent
Titan Bingie Mod
This is a great-looking skin/mod. One question (sorry if it's been asked before, but after a quick search I couldn't trace it). Is there any way of converting the sub-menus to hubs? I'm coming fro. Auramod, where I could just convert have the sub-menu items as their own widget, and 'genres' and 'studios' would take you to their own page. Thanks again, great work!
(2020-09-18, 22:46)AchillesPunks Wrote: I sent you a private message. Just send me your email, and I'll give you the episode view with the landscape turned off
Email has been sent
Thanks got it it was exactly what I wanted. Thumbs up given.
Hi everyone, is there anyway I can stop both startup splas screens? Still getting original
(2020-09-19, 19:33)pocca Wrote: Hi everyone, is there anyway I can stop both startup splas screens? Still getting original
Do a custom splashcreen and replace with a black image.
You can remove the Kodi splash by making an easy advanced settings forder and use this setting <splash>false</splash>
https://kodi.wiki/view/Advancedsettings.xml
I also use the advanced settings to increase the cache for slower streams.
I use this for my splash lol
https://youtu.be/Hs-1_HNALhw
could you post a pic of the part of your advancedsettings , for increasing cache please ?
A video was easier here you go.
https://youtu.be/oUK4_Rp2PQo
Hi all,
Any change to make the first widget raw being a bit transparent when the cursor is on the spotlight? i think it will be a nice touch
https://ibb.co/NKC2RfS
(2020-09-20, 15:12)jonsnow30 Wrote: Hi all,
I think i've got it:
https://ibb.co/XppLyXk
I added this line:
        <animation effect="fade" start="35" time="300" condition="Control.IsVisible(1508) + Integer.IsGreater(Container(77777).Position,0)">Conditional</animation>
under this line:
<animation effect="slide" end="0,-250" time="300" condition="Control.IsVisible(1508) + Integer.IsGreater(Container(77777).Position,0)">Conditional</animation>
Hi, whilst the English maps logos are on the Home Screen is there any way to change when playing a movie. Still comes with tvma on player screen?
I added this line:
under this line:
I like that a lot. Good job!
What's up with your plot/button configuration? You switched it around? The original Bingie had it like this and I was never that keen on it to be honest.
The current version:
(2020-09-20, 16:23)pocca Wrote: Hi, whilst the English maps logos are on the Home Screen is there any way to change when playing a movie. Still comes with tvma on player screen?
Not at this time. Not for the logos at least. But if you want UK age certificate text to replace the TV-XX text, you need to scrape UK age ratings.
  • 54
  • 55
  • 56(current)
  • 57
  • 58
  • 442
