2020-09-21, 12:48
(2020-09-21, 10:41)HugoL Wrote:(2020-09-21, 06:19)tankman37 Wrote: Having trouble installing 1.06. Have updated no issue from base to 1.02 then 1.05 but when I try 1.06 it fails and tells me some of the files needed for the skin are missing. Uninstalled the mod and bingie, but does the same on new install. Back using 1.05 for now....am I missing something when updating?
Can you try uninstalling again and also delete your temp folder in the addons folder and then try again?
All done. Had to reboot my shield after uninstalling everything as just uninstalling and rebooting Kodi didn't work. But now running 1.06. Thanks.
