  • 84
  • 85
  • 86(current)
  • 87
  • 88
  • 447
(2020-11-01, 03:39)HugoL Wrote: Update is live.
1.08 Changelog
Spotlight
  • New brighter spotlight widget diffuse.
  • Spotlight Widget now hides plot on idle (with a slide animation)
  • New metadata sublabel on spotlight widget (and on home & Bingie views)  Spotlight sublabel now includes top 250 on IMDB and Director metadata (Director metadata is only displays on films and only for spotlight, not bingie views).  Can be disabled via (Settings>Homescreen Layout>Details Options).
Menu
  • New menu icons for sideblade and slim menu. Increased sideblade menu width to allow for longer labels (had to alter the submenu position for this to work so it sticks out further than usual.
  • General tidy up of sideblade menu and slim menu/indicator.
  • Menu now displays a max of 6 short cuts/hubs at any time, so you can have as many as you like without affecting the look of the menu.
Details Row
  • New Option fake resolution codec.  If enabled and if your resolution and audio metadata is missing, a fake “Ultra HD 4K” flag will appear.
  • New Option for displaying TV show status (ended, cancelled or continuing)
  • New option for Audio Codecs to display only the Atmos metadata (like Netflix) providing you have the existing metadata and when Audio Codecs are enabled.
  • Removed all other audio codec logos. It’s only text & flagbox now for non ATMOS audio Codecs
  •  Added TVDB rating to the IMDB/RT details row option (RT for films, TVDB for shows)
  • General details row tidy up
OSD
  • Added the option to switch between  either ClearLogo or ClearArt when OSD is paused.
  • Added option to switch between ClearLogo or ClearArt for OSD infopanel
  • Added option to remove the current time, start time and duration of movie on OSD
  • Added option to have jump indicator show when skipping video scenes.
  • Added option to remove the discart from OSD Infopanel
  • Changed the diffuse on the OSD infopane to help highlight the infopanel better.
Other changes
  • New Circular Navigation option – Removed access to the old version. New option keeps the same layout as noncircular navigation. Sideblade Menu access is on Back command only.  We will hopefully implement menu access from position 0 On Left in the next update.  Option found via (Settings>Homescreen Layout>Widgets).
  • New Total video count in bingie library views next to header.
  • Fixed bug with widget focus position changing when more than 28+ widgets are loaded.
  • Fixed widget header scrolling when Plot Scrolling is enabled.
  • Changed the left side diffuse on home so menu icons are more visible when there is a widget directly behind it.
  • Adjusted widget heights for bingie library views (poster and landscape)
  • Tidied up Continue watching widget
  • Tided up Plots & Critics in Video Info dialogue
  • Tidied up Cast in Video Info dialogue
  • Added a season greetings Snow effect option Settings>homescreenlayout>seasons greetings
Excellent job on all of your work @HugoL
Titan Bingie Mod
1.08 Changelog
Spotlight
Menu
Details Row
OSD
Other changes
Our work, considering a lot of the work is yours!
@trkselim , @AchillesPunks
Do we really need to quote large posts and add only 1 or 2 single lines as a reaction?
Maybe I'm getting old, but a but more clever reaction would be appreciated.
(2020-11-01, 04:48)iirishguyi Wrote: Can you please just tell me where to go or how I can find out then which builds or addons are banned so I know what not to say next time. Thank you
There is the banned addons (wiki) section in our Wiki, which is by no means a definitive list. But I'm sure you'll get the idea.
Anything that is remotely illegal in terms of getting online videos, as films/tvseries/sports/etc, or music, for which you normally should pay a fee of some sorts, is off-limits here.
@HugoL @AchillesPunks fantastic work, thanks!
Thanks for the update - really great.
There are 2 minor issues that I've seen:
1. Widget headers scrolling (with plot scroll enabled) is fixed on home, but they still scroll in hubs (have fixed it by reducing font size slightly in includeshub.xml).
2. On Bingie episodes view the white frame that selects the episode appears correctly when I press right from the season to episodes, but then disappears as soon as I scroll up or down through the episodes (have tried enabling  disabling fixed frame but makes no difference).
Any help on issue 2 would be appreciated.
Great update - love the circular navigation with "always on" menu and TV Show status.
One slight issue with TV Shows on main menu widgets - how do I disable the TVDB rating?
(2020-11-01, 12:30)stevenpaulletcher Wrote: Thanks for the update - really great.
Both issues fixed, thanks a lot!
(2020-11-01, 10:25)Klojum Wrote: @trkselim , @AchillesPunks
Oh, sorry. How would I post a reply with only a small section of his post? Sorry
Titan Bingie Mod
(2020-11-01, 12:40)spinecho Wrote: Great update - love the circular navigation with "always on" menu and TV Show status.
Are you talking about the new TVDB rating on the RT/IMDB details row or on the footer?
The TVDB on IMDB/RT details row has no option to remove (via settings but I can point you to the xml or I guess I could add a setting).
(2020-11-01, 13:23)AchillesPunks Wrote: How would I post a reply with only a small section of his post? Sorry
I've just learned this myself. If you highlight some text of the person you want to reply to, a new reply option appears.  Hit the new reply option (make sure it's not the normal reply option) and it will quote just the highlighted text.
Nice feature!
Nice feature!
Oh cool. Thanks I didn't know that.
Titan Bingie Mod
WOW - thanks very much for the quick fix - working perfectly now!
Thanks for the update HugoL. Im just up and seen this so im going to get to work on it. The Mrs is gonna be peeved though... she hates my late nights playing with the mod.. but I love every second.
Thanks again.
@HugoL Thanks for the updates as always. I do hope that on the next update, you will give a bit of your attention towards the inaccurate display of the TV shows episode progress bars since I gave up trying to find the fix myself for almost a month now. Sad
where is 1.08 version Link ? First page have 1.07 link
  • 84
  • 85
  • 86(current)
  • 87
  • 88
  • 447
