  • 95
  • 96
  • 97(current)
  • 98
  • 99
  • 442
Hey my friend so i used library integration dont have a huge library yet but im working on it thank you for the advice. The resume points, season view, etc are all great i have 2 questions though outlined in the imgur post. one is the poster size inside my library view seems off like the space between posters seems bigger but im not sure could just be me reading into it wrong so let me know on that. Other is i still cant get the ratings to show up pls help https://imgur.com/a/9yuGajZ
(2020-11-06, 16:39)mathu204 Wrote: Hey my friend so i used library integration dont have a huge library yet but im working on it thank you for the advice. The resume points, season view, etc are all great i have 2 questions though outlined in the imgur post. one is the poster size inside my library view seems off like the space between posters seems bigger but im not sure could just be me reading into it wrong so let me know on that. Other is i still cant get the ratings to show up pls help https://imgur.com/a/9yuGajZ
1. Poster size in your library looks correct.  I think I told you previously, the poster size in library view is not the same as on Home screen.   However, your resolution is still wrong.  You need a 16:9 aspect ratio which you don't have and preferably resolution of 1920x1080p. What steps have you taken so far to try and fix this?
2. Looks like Achilles did something funky in the settings to remove the footer for spotlight content.  I'm going to fix it now.
Hey guys quick question I read about the last 10 pages of the thread didnt see the answer. How do you get the IMDB top 250 to work I went into my information providers and enabled IMDB and did a library scan but no dice what am I missing?
Running Matrix Titan Bingie Mod skin on Nvidia Shield to Insignia 58in 4k TV in living room. Same setup on Xiaomi Mi boxes in my bedroom and home gym. Same setup in camper with a 24in tv, Google Pixel 7 Android 13 cell phone. Kodi and Plex Server Dell Inspirion 5575 Ryzen 5 HTPC Windows 10 with 5TB external HDD
(2020-11-06, 20:09)cscott1 Wrote: Hey guys quick question I read about the last 10 pages of the thread didnt see the answer. How do you get the IMDB top 250 to work I went into my information providers and enabled IMDB and did a library scan but no dice what am I missing?
Are you talking about the new sub label one?
They should just work by default. Its been set so if doesn’t find the info in your database it will still get it from skin helper instead.
Check you have not disabled sub label on home spotlight (this ones just for the spotlight content though), found in the spotlight section of homescreen layout.
Or check you have not disabled Top250 sub label on home and bingie views found under Details Options of Homecreen Layout.
https://imgur.com/a/FDugKN8
here is the results but it never saves my changes @HugoL  for resoltuion
Thanks for the advice but both of those settings are enabled. You or anyone else have any other ideas?
(2020-11-06, 20:29)mathu204 Wrote: https://imgur.com/a/FDugKN8
Do you not have a 1920 x 1080p capable laptop?
Also, why is your monitor set to Generic PnP Monitor # 1?
Are you getting Director on spotlight content sub label (only displays on films)?
(2020-11-06, 20:28)HugoL Wrote: Are you talking about the new sub label one?
Yes
(2020-11-06, 20:39)cscott1 Wrote: Thanks for the advice but both of those settings are enabled. You or anyone else have any other ideas?
Yes
Ok.
And are you sure you’re focusing on titles that are in IMDB’s top 250?
(2020-11-06, 20:41)HugoL Wrote: Are you getting Director on spotlight content sub label (only displays on films)?
Yes
Ok.
I'm an idiot sorry for wasting your time I was just scrolling and didn't see any went to shawshank and sure enough it's there. Thanks.
(2020-11-06, 20:44)cscott1 Wrote: Yes
Ok.
No worries. You get top 250 for shows too.
Something must be up with your monitor driver. Pretty sure it shouldn't say "generic monitor".  Check you have the right driver for your laptop monitor.
no i dont think this laptop can, also idk how to change the monitor setting i cant click it or go to it so i just left it as is, my pc build is in the works this crappy laptop will just have to do for now
That I am not getting I just checked with planet earth do I need to use a particular scraper? Im using tvdb
  • 95
  • 96
  • 97(current)
  • 98
  • 99
  • 442
