2020-11-10, 01:39
(2020-11-10, 01:16)AchillesPunks Wrote:(2020-11-10, 00:57)mathu204 Wrote:I have put the large poster that transition into landscape before. Everyone said it was making there kodi build crash. I think it had to do with the trailer in the window.(2020-11-09, 20:57)HugoL Wrote: 1. Is this the Spotlight content widget not displaying the footer ratings ? If so, I fixed this when you reported it. I must have forgot to inform you! Just redownload from github.
2. I hate messing with the widgets. Change one element in widgets and then you invariably end up having to change a multitude of others to make it work properly. None of it particularly simple (for me at least). Achilles is good at that stuff but I still don't see a new layout happening to be honest. We could probably edit an existing layout easily enough to do the top 10 one but I really don't understand where this top 10 information is supposed to come from!
3. That's definitely possible yeah. Just tag any of your chosen titles and then create the smart playlist based on the tags.
For 2 check my response above, basically rather than making complicated work on how to find a top 10, jusr maken a widget aspect that goes one thru 10, a poster with number on left; then from there it’s just up to U what widget path u use and how u sort it. Not perfect but good enough.
And damn that’s a shame i would love to see the large poster landscape widget but I hope maybe it can be reconsidered in the future.
Maybe I can give it another go and try removing the trailer option.
yes that would be dope i would be glad to test for you or something if possible, with the trailers or without! Also for reference if you dont use the trailer look up LandscapePoster widget style from Auramod, its basically how it should look only difference being the size, as netflix version posters are much larger!
