2020-11-25, 21:55
2020-11-25, 22:49
2020-11-25, 23:29
Recently my all ratings and studio logos appears to load after 10 to 15 second . What might be cause or can we change in some skin settings so that it appears instant on home screen? Because other skins have instant rating and logos to appear.
2020-11-25, 23:55
(2020-11-25, 22:49)cscott1 Wrote: Here is another video that may or may not be helpful.
https://youtu.be/mmnszgYnr9E
The metadata editor is looking at your database ratings. As I mentioned, I don’t think TVDB scraper scrapes this info.
And that’s the reason why I’m saying you have a skinhelper/artwork & metadata module issue since it’s using skinhelper to grab this info.
And it’s most likely the reason why you’re not getting Metacritic and RT scores on your footer too.
2020-11-25, 23:59
(2020-11-24, 21:26)neurosis13 Wrote: HugoL,@cscott1 Might be worth giving this a shot?
maybe they need the older versions of skin helper and cherrypy.
http://www.mediafire.com/file/j5v515bd2h...1.zip/file
http://www.mediafire.com/file/qsrk5rku2c...1.zip/file
I strangely need these older versions on my Mac while on my Nvidia shield the ratings show up with the updated scripts.
Or as I mentioned previously, try deleting all the bingie dependencies and then reinstall OG bingie 1.03 to get the dependencies back.
2020-11-26, 00:06
(2020-11-25, 23:55)HugoL Wrote:I went ahead and bought a patreon OMDB api and punched it into my artwork and metadata module going to delete my simplecache database.db see if it works.(2020-11-25, 22:49)cscott1 Wrote: Here is another video that may or may not be helpful.
2020-11-26, 00:23
(2020-11-25, 23:59)HugoL Wrote:(2020-11-24, 21:26)neurosis13 Wrote: HugoL,@cscott1 Might be worth giving this a shot?
I tried these replacing the files with theses older ones all it did was give me skin helper errors. It won't allow me to delete the dependencies because it says that Bingie and Bingie mod need them. Would it be the same if I deleted them manually with a file manager?
2020-11-26, 00:49
Ok so my patreon imdb api along with deleting the simplecach file seemed to help now I am getting all IMDB and TVDB ratings for tv shows and all IMDB top 250, IMDB and TMDb ratings for Movies hoping after they are done caching I get the other ratings as well.
2020-11-26, 00:49
(2020-11-26, 00:23)cscott1 Wrote:(2020-11-25, 23:59)HugoL Wrote:(2020-11-24, 21:26)neurosis13 Wrote: HugoL,@cscott1 Might be worth giving this a shot?
If you load up Estuary you can delete them.
2020-11-26, 07:20
@Achiles
Hey man, I just finished customizing my widgets and pages and stuff but I'm getting this black screen and it's not showing anything. I can click select on my remote and hear the tick noises but nothing happens. I'm using Kodi 18.8 as well on a Shield. I downloaded the BINGIE repo as well as your mod zip. My skin is set to Titan Bingie Mod.
https://ibb.co/2dXmtXh
Here's an image of what happens. I can also hold the back button to bring up that bottom bar that has settings and reload skin and stuff but that's about it. I tried restarting kodi and the skin and still get this black screen.
2020-11-26, 08:47
(2020-11-26, 00:49)cscott1 Wrote: Ok so my patreon imdb api along with deleting the simplecach file seemed to help now I am getting all IMDB and TVDB ratings for tv shows and all IMDB top 250, IMDB and TMDb ratings for Movies hoping after they are done caching I get the other ratings as well.
Oh.. Only patreon OMDB API will work. Can someone confirm whether Free (1000 requests daily) OMDB API will work or not?
2020-11-26, 09:46
Strange! "Music" appears in the Configure shortcuts->Edit menu shortcuts, but is not shown in the Main Menu. I can't figure out how to bring it to the Main Menu.
"Music" is not shown in Configure shortcuts->Edit menu shortcuts->Change Shortcut->Common, so I can't add/change it.
Please help.
Please help.
2020-11-26, 12:02
(2020-11-26, 08:47)karthikm Wrote:(2020-11-26, 00:49)cscott1 Wrote: Ok so my patreon imdb api along with deleting the simplecach file seemed to help now I am getting all IMDB and TVDB ratings for tv shows and all IMDB top 250, IMDB and TMDb ratings for Movies hoping after they are done caching I get the other ratings as well.
I think it will work but only 1000 requests daily.
2020-11-26, 13:56
So made some progress yesterday with getting ratings to display in the footer. I have all the TMDB, IMDB, IMDB top 250, Rotten Tomatoes and Metacritics for my movies subsequently all these can be scraped by adding your OMDB api to the Universal Movie scraper. I have all TVDB and IMDB ratings for TV shows which are scraped from TVDB. I have only a handful of Rotten Tomato scores for tv shows I assume they are coming from the skinhelper/artwork & metadata module. Still no IMDB top 250 TV shows or Metacritics for shows. I left my Shield on when I went to work with auto rotate widgets on hoping that rotating through the widgets will help the others to appear but who knows.
