2020-12-04, 16:40
(This post was last modified: 2020-12-04, 17:25 by cscott1.)
I'm only getting a few cast info (red star)on the homepage. Is this information being pulled from skinhelper and Im stuck with only what it pulls from the Metadata and Artwork module with all my APIs plugged in or does it pulled from scraped info? The cast info is being pulled for most if not all of the widget I have linked to an add-on but again only a few in my library. Any insight on this how can I get more cast info for my library if possible?
Running Matrix Titan Bingie Mod skin on Nvidia Shield to Insignia 58in 4k TV in living room. Same setup on Xiaomi Mi boxes in my bedroom and home gym. Same setup in camper with a 24in tv, Google Pixel 7 Android 13 cell phone. Kodi and Plex Server Dell Inspirion 5575 Ryzen 5 HTPC Windows 10 with 5TB external HDD
2020-12-04, 21:28
(This post was last modified: 2020-12-04, 21:29 by cscott1.)
I just found out that TVDB will be changing to a paid service starting next month where you will have to pay a monthly fee to use their API. One of the skins dependencies is a python module The TVDB API v2 how will this affect the skin?
minhgi
Junior Member
2020-12-05, 01:27
(This post was last modified: 2020-12-05, 01:29 by minhgi.)
1.09 solved the Vietnamese unicode issue. It is showing correctly now. It might solve other language problems too.
I have only two problems. Top 250 imdb doesn't getting pull or showing in the spotlight or home footer. Could be an issue with thier server? The widget group name now scroll up and disappear for 15 seconds. That was fix from 1.08.
Other than that, I like all the new additions that have been added to 1.09. Awesome works. Thanks.
minhgi
Junior Member
2020-12-05, 03:12
(This post was last modified: 2020-12-05, 03:12 by minhgi.)
Yes. Top 250, top 100, and etc works with 1.08. I do have backup prior to updating to 1.09.
I did a restore from a back up and the top 250 isnt showing either. I already purge the simplecache to be sure. Anyway, I'm thinking the top 250 data aren't getting pull. So it could be server side issue and not with titan bingie mod. I was check back on the next few days if there any change.
Awesome work btw. Thanks.
