2020-12-22, 15:38
(2020-12-22, 15:24)cscott1 Wrote:(2020-12-22, 15:10)mjeshurun Wrote:Honestly I'm an Android and Windows guy not really familiar with ras pi operating systems. Have you tried using OSMC instead of Kodi from the little bit I have read that seems to be the go to system for ras pies and all kodi addons are compatible with it.(2020-12-22, 15:01)cscott1 Wrote: After uninstalling kodi on my android devices I always power off the system for a few minutes before reinstalling because there always seems to be some leftovers. Just curious why are you using a ras pie? They are so flaky, they might be fun to build and tinker with but not the most reliable streamer. There are a lot of affordable options right now. I Just purchased a Dynalink Android TV box for $29.50 from walmart runs official Android TV and Android 10. I have kodi 18.9 with the Bingie mod installed on it along with the official Netflix, Amazon Prime, Hulu, and many more, I highly recommend it I barely notice a difference between it and my Nvidia Shield.
Hi @cscott1
I bought a Raspberry Pi 4 (4GB) to use as an OpenHAB smart home system. And since I already have the Raspberry Pi, I figured I’d use it also for Kodi.
Is there a particular terminal command to completely uninstall kodi with all its dependencies and addons?
Thanks for the tip about OSMC, but I’m not sure it’ll be a good solution for me.
First and for most, I need to use Raspberry Pi OS to power my smart home system.
I understand OSMC is an alternative full OS that supports running apps, but, reconfiguring my smart home systems OSMC might be problematic.
Therefore, I prefer to stay with the official Raspberry Pi OS.
