  • 134
  • 135
  • 136(current)
  • 137
  • 138
  • 442
(2020-12-26, 14:23)redglory Wrote:
(2020-12-26, 08:16)nazim12 Wrote:
(2020-12-24, 14:09)redglory Wrote: If you don't mind editing some file, take a look at this mod's github here
remove the limit parameter or change to your preference
Minorly  working after your suggestions , Let say I have Horror movies around 1500 but in searching a playlist ( Horror)  showing around 400 movies . but when I set a widget of ''Horror'' on home screen it does show all 1500 horror movies.
Firstly, it's not recommended to have more than 20/30 entries on a widget. It will make your skin somewhat slow.
You can set a playlist as your widget. Just defined how much results you want to limit and set it on home screen.
OK you know search section in binge , when we go to that section there are many playlists showing in that section
When we click any playlist under that section it only shows limited result , i have set 1000 there as you suggested but search results nor surpassing 400 items.
(2020-12-26, 08:30)nazim12 Wrote: And I tried many things but percentage of ''In Progress Media '' does work for some time but when I refresh home widgets , Percentage reset back to 0% for all Movies & TV Shows although movies plays from the exact resume point with 0% on Posters .
Does the addon in question rhyme with Zen
How do I get Fast forward and Rewind button on Playback screen. There's no option to add them
Yes. It is
Any plans for kodi 19??
Hello, first of all thank you for the work with this skin.
Could it be, that the function to change the music OSD was deactivated with the last update? Huh
Yes. It is
Disable mark watched in Library when watched in Zen
(2020-12-27, 06:03)mathu204 Wrote: Does the addon in question rhyme with Zen
Yes. It is
I think, it solved .Thanks
Edit: it definitely worked.
(2020-12-26, 04:55)mathu204 Wrote:
(2020-12-25, 15:09)cscott1 Wrote:
(2020-12-25, 02:02)mathu204 Wrote: Bump on this?
Is it showing the correct episode information and just skipping ahead or is it playing the wrong episode for the information listed? I have the latter sometimes but it's not a skin related issue sometimes there will be a special or a two part episode that the streaming addon will have listed improperly. I watched a whole season of a show where the I was always an episode ahead of what it was listed it eventually righted itself.
So lets say I am on 1x02 of a show. I click play on it and back out real quick without it even playing bc i realized i dont want to watch this show. When I back out the widget Continue Watching on my home will show 1x03 instead of 1x02 now instead even though there is no progress on 1x02, and it is not watched, not sure if its skin related or not but i assume Kodi thinks that I played 1x02 or somehting and shows 1x03. If i press it and play it it will play 1x03 (the correct one for what it shows; but it shows the wrong episode which is the problem). If i go into More Episodes below it will correctly show I have no progress on 1x02, but the widget will always show 1x03 as my current episode even though it knows its not the right one bc going into More Episodes shows it correctly.
So far the only way to fix this is Marking 1x02, and 1x03 watched, then marking both as unwatched and then going back to the home screen in which it will update to 1x02.
Or by going into More Episodes, playing 1x02 part way enough to leave a playback progress in which when I go back it will show x% 1x02 correctly.
Glad you got it working Nazim no prob, now I have some questions for you nice folk at Titan Bingie Mod lol. Numbered and an imgur link to reference.
1. This is just continuing off the quoted thread above the first two images are just 2 pictures of it if i didnt explain it well enough. Wrong episode sometimes shows on Next episodes widget.
2. Im Not sure if this is meant to work this way, and if it is maybe you would consider changing it. So in the in progress episodes, it shows a red progress bar to visualize where you are in the episode. This bar does not show up for Movies in the main view. When i press info and it shows resume the bar is there so it is not like it isn't there or is it not possible to create. If there is a reason you dont add this why not? Is it cause its not like this in Netfilx, or cause there is a limitation of some sort? I do think that putting the bar for movies too would be nice as it makes for a more constant experience.
3. I dont encounter often but I added the movie Taken to my library and it said New episodes rather than New. Is the function to say "New" for movies that are recently added possible or there? It may just be a one off bug bc i added a show called Taken to my library at the same time too but just raising this. Not that serious but yea.
4. Some shows have names for seasons like DBZ, Naruto, or Archer, etc. The problem I have with this though is when I go into Bingie Episodes view, the seasons on the left are incorrectly ordered, I think it goes alphabetically which messes up the whole order. So far my only way to solve this is to switch to TVDB scraper, but as many of you know unfortunately TVDB may be switching to paid soon. Do u think u can make it so Bingie Episode view orders season by release date or something else instead to make it more accurate? Also the folders in my library are named Seasons 1 thru 9, the information provider is what gave the seasons these names.
5. Lastly, in the last image you can see there is a movie with only an iMDB, and TMDB rating. With RT Audience set as the default there is no "x% liked" status on the details row, can you consider making it so when the default rating is not available that it fallbacks to any of the other ratings that are available? In this case of the image, IMDB or TMDB.
https://imgur.com/a/CaWaJcE
Spotlight without first widget row
https://imgur.com/gallery/uOGdz4X
(2020-12-25, 15:09)cscott1 Wrote: Is it showing the correct episode information and just skipping ahead or is it playing the wrong episode for the information listed? I have the latter sometimes but it's not a skin related issue sometimes there will be a special or a two part episode that the streaming addon will have listed improperly. I watched a whole season of a show where the I was always an episode ahead of what it was listed it eventually righted itself.
I don't get it all.
4- episode view in Netflix are by season numbers ,change in zen show tv shows special  when available ''Off'' and use season titles when available ''off''
5-In my case it always give imdb or tmdb as default  in case of RT default is missing
2- Bar for movies  I also raise request to Achiless
1- it happened usually when addon refused to play episode Link or partial played broken link .stream started and ended ,kodi think its played full ,it happened with me when I play 4K HDR with external player(PotPlayer with Mad)
(2020-12-26, 04:55)mathu204 Wrote: So lets say I am on 1x02 of a show. I click play on it and back out real quick without it even playing bc i realized i dont want to watch this show. When I back out the widget Continue Watching on my home will show 1x03 instead of 1x02 now instead even though there is no progress on 1x02, and it is not watched, not sure if its skin related or not but i assume Kodi thinks that I played 1x02 or somehting and shows 1x03. If i press it and play it it will play 1x03 (the correct one for what it shows; but it shows the wrong episode which is the problem). If i go into More Episodes below it will correctly show I have no progress on 1x02, but the widget will always show 1x03 as my current episode even though it knows its not the right one bc going into More Episodes shows it correctly.
I don't get it all.
4- That picture is from local library content all of my widgets and content is from library content that I imported as .strms from official TMDBHelper addon. The scraper I used for those shows is TMDB, if u check on TMDB for those shows the seasons are named like that
(2020-12-28, 06:43)trkselim Wrote: Spotlight without first widget row
Looks nice! I can’t tell what spotlight diffuse mask you’re using but you should try the original one (if you’re not already using it) as it should help increase the black space. Your plot text seems to run off significantly into the fanart making it unreadable.
Search for new_bingie_Spotlight_diffuse1.png in includesbingie and remove the “1” so it now says “new_bingie_Spotlight_diffuse.png”
Either that or maybe just make the fanart a little smaller.
It’s looks better
It’s looks better
Did you edit the skin yourself to get the spotlight to look liek that? or was there an update i missed?
  • 134
  • 135
  • 136(current)
  • 137
  • 138
  • 442
