  • 141
  • 142
  • 143(current)
  • 144
  • 145
  • 444
Here are my TVShow clearlogos if anyones interested, Ill do movies on a later date lol.  These arent the best but hey better than plain text, and when Acchiles comes out just replace mine with their better ones. I have a few shows outside of Netflix that I added clearlogos for in here too
https://www.dropbox.com/sh/crdha55nee3wq...vsxba?dl=0
adjusted ratings icons a little more.
Titan Bingie Mod
[font][font]Ciao, perdona il mio inglese, sono italiano! [/font][/font]
[font][font]Grazie in anticipo per l'ottimo lavoro! [/font][/font]
[font][font]Tuttavia, come posso fare per disabilitare l'aggiornamento automatico di Spotlight ogni volta che cambio voce di menu?[/font][/font]
Hi, forgive my English, I'm Italian!
Thanks in advance for the excellent work!
However, how can I do to disable the auto update of spotlight every time I change menu item?
(2021-01-10, 09:40)AchillesPunks Wrote: I have also created some clearlogos for Netfilx Series and Films. I will add them to a download later. Examples below.
With these clearlogos are they entire clearlogos or just the N series header? I like the idea.
Running Matrix Titan Bingie Mod skin on Nvidia Shield to Insignia 58in 4k TV in living room. Same setup on Xiaomi Mi boxes in my bedroom and home gym. Same setup in camper with a 24in tv, Google Pixel 7 Android 13 cell phone. Kodi and Plex Server Dell Inspirion 5575 Ryzen 5 HTPC Windows 10 with 5TB external HDD
Does anyone else get this here in the red circle where the diffuse i think u call it is on top of the white bar and a bit of the poster??
(2021-01-11, 23:39)mathu204 Wrote: Image
No I don't. Have you made any adjustments of your own? That's the only way I see it doing that.
Titan Bingie Mod
I did but i made backups of the files I edited and put them back cause it wasnt working but maybe Ill just fresh install again later.
(2021-01-11, 08:07)AchillesPunks Wrote: adjusted ratings icons a little more.
How did you get the progress bar to show up on your movies widgets?
I added in so I could see the progress of the currently watching movies
Titan Bingie Mod
is it an xml change if so would u mind sharing it?
(2021-01-12, 05:51)mathu204 Wrote: How did you get the progress bar to show up on your movies widgets?
It is but I'm at work till 6am. I can send it to you tomorrow. Just send me your email address
Titan Bingie Mod
(2021-01-12, 05:56)AchillesPunks Wrote:
(2021-01-12, 05:54)mathu204 Wrote: [quote="AchillesPunks" pid='3002426' dateline='1610423660']
[/, yes whenever no rush. Thank you in advance Big Grin
[font][font]Bonjour
J'ai remarqué un bug lors de la lecture des bande-annonce automatique.
Lorsque je vais sur un film la bande annonce ce lance sans problème, mais quand je sélectionne la vidéo qui se trouve à coté la bande annonce ce lance pas.
Une chose que j'ai remarqué c'est quand je sélectionne 2 film à coté la bande annonce se lance bien.
C'est juste que un seule décalage droit ou gauche, la bande annonce se lance pas
Avez vous le même problème
merci pour votre réponse  [/font][/font]
I haven't forgotten. I woke up late. I'll send later
Titan Bingie Mod
  • 141
  • 142
  • 143(current)
  • 144
  • 145
  • 444
