  • 145
  • 146
  • 147(current)
  • 148
  • 149
  • 443
(2021-01-16, 22:45)AchillesPunks Wrote:
(2021-01-16, 22:42)mathu204 Wrote:
(2021-01-16, 22:35)AchillesPunks Wrote: is your library local or streams like nazim? I have 7 thousand movies and tv shows, and I don't use streams. I have 50 thousand Gigs or 50 terabyte HDDs. It does take a long time to scan movies. If you stream you don't own the movies
I stream, the only physical media I have is my dragon ball, z, gt collection. But I’ve made up my library of .strm files from TMDBHelper
You should build a library of local media. It makes the skin faster.
I do have local media in the form of .strms, or does physical media over that make a benefit? I assumed just library content over streams would already benefit immensely
(2021-01-16, 22:42)mathu204 Wrote: I stream, the only physical media I have is my dragon ball, z, gt collection. But I’ve made up my library of .strm files from TMDBHelper
Physical media makes a huge difference. All of mine is stored on HDDs with trailers. I could watch movies and trailers without internet. I just hit 7,002 movies and shows.
Titan Bingie Mod
Do you have animated posters and fanart for your media?
Titan Bingie Mod
(2021-01-16, 22:45)AchillesPunks Wrote: You should build a library of local media. It makes the skin faster.
Oh man that is a lot I wouldn’t even know where to start, I am planning on getting a NAS in the future so i will start building a physical library then, does physical content through a network drive work just as well or does it have to be on the same device?
No animated posters, I do have fan art and stuff. But honestly I don’t have any speed issues to be honest bingie works pretty fine and if it is a bit slow at times I just attribute it to the skin being heavy it doesn’t annoy me, the library taking long to scan is the only thing and even then I don’t mind too much since I try not to do a full refresh often
(2021-01-16, 22:49)mathu204 Wrote: I do have local media in the form of .strms, or does physical media over that make a benefit? I assumed just library content over streams would already benefit immensely
If you want some I can give you animated posters
Titan Bingie Mod
(2021-01-16, 23:28)AchillesPunks Wrote: Do you have animated posters and fanart for your media?
I like to keep consistency but I would actually be really interested just 1 or 2 would be nice! thank you!
So I used Texture tool to extract the images which ones are for the footers? Old and new?
(2021-01-17, 02:11)mathu204 Wrote: No animated posters, I do have fan art and stuff. But honestly I don’t have any speed issues to be honest bingie works pretty fine and if it is a bit slow at times I just attribute it to the skin being heavy it doesn’t annoy me, the library taking long to scan is the only thing and even then I don’t mind too much since I try not to do a full refresh often
I see different versions of the logos in the bingie folder and the flags folder
(2021-01-17, 02:18)AchillesPunks Wrote: If you want some I can give you animated posters
The Bingie folder is the new footer
Titan Bingie Mod
[font][font]Bonjour
quel fichier XML gère les bande annonce automatique
merci[/font][/font]
(2021-01-16, 22:44)AchillesPunks Wrote:
(2021-01-16, 22:34)nazim12 Wrote:
(2021-01-16, 22:12)mathu204 Wrote: There is no UMS for tv shows?? And I may be able to get the artwork for the episode but the plot is still missing which still bugs me. But thank u for the artwork beef top I will use that. Also scanning my library takes a long time not sure why I have less stuff than u too but when I build my new pc hopefully it will be better.
Tmdb scrapper for tv shows work fine with library scanning and will try to find full details of newely episodes .
I already sent you the xmls to the email you first sent me.
Thanks got it , One suggestion ''Continued watching episode'' does have Red Progress Bar but can you add Red progress bar to ''In Progress TV Shows '' because ''Continued watching episode'' doesn't have Landscape its just a fanart used as landscape which looks weird and ugly some time .
My all movies fake codec saying ''Released'' instead of ''Ultra HD 4K'' , How to set ''Ultra HD 4K'' Permanently Huh?
Hi, i have installed the BINGIE repository and then Titan BINGIE MOD from zipfile on a fresh install but this is what I get when I switch the skin to Titan BINGIE MOD:
Any idea ?
(2021-01-17, 18:44)yoyo2000 Wrote: Hi, i have installed the BINGIE repository and then Titan BINGIE MOD from zipfile on a fresh install but this is what I get when I switch the skin to Titan BINGIE MOD:
Any idea ?
press esc button at least 6 times . it will gone.
  • 145
  • 146
  • 147(current)
  • 148
  • 149
  • 443
