  • 147
  • 148
  • 149(current)
  • 150
  • 151
  • 447
(2021-01-18, 14:37)AchillesPunks Wrote:
(2021-01-18, 01:55)mathu204 Wrote: Hey got a request, I am making a Titan Bingie Mod build for my friend who recently just got into Kodi, I dont want to set him up with library stuff as itd be too overwhelming as the stuff im already showing is complicated enough. My request is for in progress episodes that show 0%, I know  that we cant get the correct progress to show up which is fine it is a limitation of addons but can we make it so it shows a dummy progress bar thats like 1% in on the home screen under the title? And also on the bingie episodes view? I know this is kinda possible because it already shows this dummy progress when u press info on the episode or movie that shows 0% progress. Shown in the imgur link here. Maybe an option to enable if people dont want it but for the people using  library stuff like you guys and myself it woudlnt make any difference anway.
https://imgur.com/a/v8RdVLo
Ive titled and detailed a bit more of what i mean in the link please let me know your thoughts, i would very much appreciate it if you could consider it.
EDIT: Im juggling a lot of things rn but I have not forgotten about trying to edit the icons
I would have to look on my days off from work. I work till Wednesday.
No problem i appreciate you even considering looking into it to begin with since ik you guys are not fans of streams at least with Bingie mod, being that it revolved around physical media. I have another question, this ones not really a request i dont want to give u guys extra work but if u could tell me if its doable maybe i can try to figure out what I can do myself. So since Bingies search hub is built for library content and cant be used with addons, is there a way to convert the search hub into just another empty hub (like that i can fill with widgets?) and just turn it into my own search hub of widgets and a submenu?
(2021-01-18, 15:20)cscott1 Wrote:
(2021-01-17, 14:11)nazim12 Wrote: Image
My all movies fake codec saying ''Released'' instead of ''Ultra HD 4K'' , How to set ''Ultra HD 4K'' Permanently Huh?
Skin settings/Homescrean layout/Details/untick Show TV Status on Details Row Home & Bingie Views.
Is there a way to show TV Show status for shows but keep the 4K on movies?
Not unless you edit the xml
Titan Bingie Mod
I did a skin reset that was enough. Thank you for your help Smile
(2021-01-17, 23:15)nazim12 Wrote:
(2021-01-17, 23:10)Axl2 Wrote: it doesn't work for me. It installs later trying to set my data with bingie 1.03 and all of a sudden the pictures appear in a black screen that says netflix. No button works Sad
Reset Kodi  or add one more profile .
Omg, i was thinking it will be long hassle to set ultra hd 4k permanently, but you solved it. Thanks a lot
No problem just giving you the advice Hugo gave me when I had the same problem a few months back.
Running Matrix Titan Bingie Mod skin on Nvidia Shield to Insignia 58in 4k TV in living room. Same setup on Xiaomi Mi boxes in my bedroom and home gym. Same setup in camper with a 24in tv, Google Pixel 7 Android 13 cell phone. Kodi and Plex Server Dell Inspirion 5575 Ryzen 5 HTPC Windows 10 with 5TB external HDD
Not that I'm aware of.
how do u add more source ratings for movies/shows? only getting tmdb atm
Hello! i want to use Kodi for retro gaming, how can i change all movie stuff for games using Internet Archive Game Launcher?
(2021-01-19, 02:28)conkrastil Wrote: how do u add more source ratings for movies/shows? only getting tmdb atm
Scan all media with universal movie scraper
Titan Bingie Mod
Hello
Which XML file manages automatic trailers
thank you
Hi All,
Just wondering if I could get some help with something i'm stuck on. What I would like to do it have two widgets at the top (Continue Watching and Recently Added) and then below that, two lists which are (ALL MOVIES) and (ALL TV SHOWS).
I have the Continue Watching and Recently Added working but i'm having trouble figuring out how to display the entire Movie and TV Show lists below. I've attached a mockup of what i'm trying to achieve.
Any help would be greatly appreciated!
(2021-01-19, 23:49)cabro Wrote: Hi All,
Select title for movies and title for tv shows.
Titan Bingie Mod
(2021-01-18, 15:20)cscott1 Wrote: Skin settings/Homescrean layout/Details/untick Show TV Status on Details Row Home & Bingie Views.
is it a somewhat easy edit? could u point me at what i would have to do if its not too difficult?
(2021-01-18, 23:03)mathu204 Wrote: Is there a way to show TV Show status for shows but keep the 4K on movies?
I think it's in the includesbingie.xml but not 100% sure. I'm at work right now until 6am. I may check tomorrow if I get on my PC.
Titan Bingie Mod
(2021-01-19, 00:51)AchillesPunks Wrote: Not unless you edit the xml
No worries its not a big deal!
  • 147
  • 148
  • 149(current)
  • 150
  • 151
  • 447
