  • 156
  • 157
  • 158(current)
  • 159
  • 160
  • 439
(2021-02-07, 14:02)mind12 Wrote:
I tried to use your skin mod but after switching to it this is what I get: Image
I used the aeonmq18 skin before.
I installed the skin and all dependencies from the repo and then installed the modded zip file.
If I switch to the normal titan bingie skin it works.
Any idea what could cause this?
Kodi.log has these entries:
2021-02-07 12:58:28.816 T:6124  NOTICE:   load skin from: C:\Users\Kodi\AppData\Roaming\Kodi\addons\skin.titan.bingie.mod (version: 1.0.9-mod)
2021-02-07 12:58:29.365 T:6124   ERROR: Window Translator: Can't find window InfoDialog
2021-02-07 12:58:29.378 T:6124   ERROR: unmatched parentheses in string.isempty(skinhelper.autoclosevideoosd))
2021-02-07 12:58:29.826 T:6124 WARNING: Trying to add unsupported control type 1
2021-02-07 12:58:29.842 T:6124 WARNING: Previous line repeats 2 times.
Press esc at least 6 times. see post 2202
Can anyone help me out here? I keep getting this randomly on Titan Bingie Mod, and switching skins to estuary and back fixes it but I dont want to  have to keep doing it, and I also dont want to fresh install as I put in wayyyy too much work on this setup
Edit: Happens everytime on startup
Edit 2: so again changing skins and back fixes it or changing skin, then pressing no. Also just restored from a backup to see if it would fix it but it didnt, however the skin rewrite on the first open fixed it. so writing menu also fixes it if thats of any valuable information
Edit 3: figured it out, enabling login screen in profiles is what caused this not sure why
Oh Also, do $INFO List.Item.Property tags not work inside hubs? THey worked on the home screen for me but not on Hub widgets sadly
(2021-02-08, 01:36)mathu204 Wrote: Oh Also, do $INFO List.Item.Property tags not work inside hubs? THey worked on the home screen for me but not on Hub widgets sadly
I couldn't get them to work either. That's really the only issue I have with this skin
Damn that sucks hopefully it can be changed later
Awesome it's working now.
Do you know where can I find this settings? - "Just note apply the NETFLIX COLOR THEME in Settings by @AchillesPunks."
THX
Hello, I didn’t get any answer to my question #2337
THX
It's under color theme setting.
Titan Bingie Mod
(2021-02-08, 17:01)Bungee_G Wrote: Hello, I didn’t get any answer to my question #2337
What is your setup?
Titan Bingie Mod
What is your setup?
Hello, I want to use this skin both on my Android tv and windows 10 pc, the issue occurs on both
(2021-02-07, 20:47)yoyo2000 Wrote: Press esc at least 6 times. see post 2202
THX
Got it thx. I looked for it under Interface/color theme.
I have some other questions:
- What triggers the spotlight content refresh? Is the interval configurable somewhere?
- How can I modify the now playing music layout and enter fullscreen when the playing starts?
A note to anyone having the same issue:
If you setup the skin and it just shows a black screen, with the logo and sidebar you can't navigate through: Change the skin to something that works using file explorer or similar, then go into settings and set the startup screen to settings instead of home (so you can fix stuff if it's broken again). After that go open the skin settings, select the bingie skin, open the settings of the skin -> configure shortcuts -> Reset menu to skin's defaults. That fixed everything for me.
Apart from that I am having one issue though:
When I browse the episodes of a series it just shows the episode and a spinning disk above it. No plot, media tags only in bottom left hand corner. What do I need to change to fix this?
(2021-02-10, 02:56)Jalau Wrote: A note to anyone having the same issue:
Send me a screenshot please
Titan Bingie Mod
(2021-02-08, 15:17)mind12 Wrote: Awesome it's working now.
THX
I removed a lot of the music settings in the skin. I only use skin for movies and TV and didn't want to maintain music settings.
Titan Bingie Mod
(2021-02-09, 00:42)AchillesPunks Wrote: It's under color theme setting.
can you please write a quick tutorial on how to download the mod on kodi on a firestick tv??
  • 156
  • 157
  • 158(current)
  • 159
  • 160
  • 439
