  • 172
  • 173
  • 174(current)
  • 175
  • 176
  • 443
(2021-03-20, 08:19)AchillesPunks Wrote:
(2021-03-20, 06:38)trkselim Wrote:
(2021-03-20, 00:40)AchillesPunks Wrote: Just replied
I sent you email
Very nice. I really like that.
I have Plex Kodi connect and in many movies titles the Greek characters are not supported. (square symbols instead)
Any solution for that?
Please tell me how to enable sub label (movie slogan) under the movie logo on the main menu? I found a sub label in the settings, but even when it is turned on, it does not show the slogan of the movie ... I have version 1.0.9
(2021-03-20, 10:30)jokero009 Wrote: Please tell me how to enable sub label (movie slogan) under the movie logo on the main menu? I found a sub label in the settings, but even when it is turned on, it does not show the slogan of the movie ... I have version 1.0.9
Make sure you're .nfo has the sub label added or it will not show. It has to do with how your media is scanned.
Titan Bingie Mod
(2021-03-20, 06:38)trkselim Wrote: I sent you email
I'll take a look at this today after I wake up.
Titan Bingie Mod
(2021-03-20, 07:24)ryadre Wrote:
(2021-03-20, 06:22)AchillesPunks Wrote:
(2021-03-20, 06:04)ryadre Wrote: I would have thought so, I have looked everywhere for it lol, any idea what it's called?
Are you using a mouse? If so I can't help you because I use a computer TV remote. You can try clicking the force stop playback when not in fullscreen.
Didn't work
Someone with a shield will have to give you a hand. I only use PC
Titan Bingie Mod
I use coreelec , and nas sharing files if you want somebody to test
(2021-03-20, 01:32)ryadre Wrote: Can anyone point me in the right direction what to change to bring up osd without playback pausing?
Well since you have a shield limited options, either need a usb keyboard so you could press the ‘I’ key to bring up ocd info, or in the Kodi addon repo>Program addons>key map editor allows you to reprogram remote keys to do certain functions such as bring up the ocd you could try? I have a shield but I have a Logitech harmony remote and it has a info button on it which brings up the ocd for me during playback.
Otherwise I’m not sure there’s a switch for that in the settings that works without you having the right key to press.
(2021-03-20, 15:52)javcarbe Wrote: I use coreelec , and nas sharing files if you want somebody to test
It needs to be local media on HDDS. No streaming.
Titan Bingie Mod
I wouldn't even be able to add a button in settings for this since I can not test.
Titan Bingie Mod
Thanks, I had thought of that, but when I set a button to show osd it still pauses it. I will have another go at it maybe with an info setting if I can
I sent you email
(2021-03-20, 08:19)AchillesPunks Wrote: Very nice. I really like that.
I sent you email
Got it and just got done looking over the XML. I'll test in about 2 hours.
Titan Bingie Mod
hello,
i'm a noob in skins so please be gentle.
Spotlight stays stuck on just 1 item. how do i get it to cycle through random entries.  and also the speed of the changes. i'd like it to change like every 15 seconds
PS:
if anyone has the proper Netflix look setup with just local files,  please share your XML with me.
i'm really struggling with setup.
(2021-03-20, 00:32)AchillesPunks Wrote:
(2021-03-17, 14:16)cscott1 Wrote:
(2021-03-17, 14:15)AchillesPunks Wrote: That was fast cscott
That's what she said.
@cscott1 do you have local media library? I need you to test something for me on Matrix. I only use local media from HDDs and the change isn't working for me, but for @matke who uses stream it's working.
My library is a fake local library I use addon integration.
Running Matrix Titan Bingie Mod skin on Nvidia Shield to Insignia 58in 4k TV in living room. Same setup on Xiaomi Mi boxes in my bedroom and home gym. Same setup in camper with a 24in tv, Google Pixel 7 Android 13 cell phone. Kodi and Plex Server Dell Inspirion 5575 Ryzen 5 HTPC Windows 10 with 5TB external HDD
  • 172
  • 173
  • 174(current)
  • 175
  • 176
  • 443
