  • 187
  • 188
  • 189(current)
  • 190
  • 191
  • 443
(2021-04-22, 07:04)AchillesPunks Wrote:
(2021-04-16, 21:15)nazim12 Wrote: @Achiles  How can we resize  ''fix focus Frame'' size ? I just want minorly increase the size of Frame.
I'll look at this tomorrow
Hi
Thx for skin
When available skin in repository??
(2021-04-20, 20:46)nazim12 Wrote:
(2021-04-20, 19:03)matke Wrote:
(2021-04-20, 17:06)nazim12 Wrote: Any Reply regarding this?
Settings/General skin settings/Bordersize for focused thumbs/tiles
Sorry not what I meant , I have increased Poster size and if I Choose Fix focus Frame Movement then default size of frame doesn't applied on my increased size posters so I need to increase frame size as well to match with poster size .
It's in the includesbingie xml. Just change to your liking.
Titan Bingie Mod
(2021-04-20, 19:03)matke Wrote: Settings/General skin settings/Bordersize for focused thumbs/tiles
Thanks a lot.
Hi
Thx for skin
Soon
Titan Bingie Mod
(2021-04-22, 07:04)AchillesPunks Wrote: I'll look at this tomorrow
Hi
Thx for skin
Soon
Dont know if u saw what i posted earlier but i just think it would make things easier for you if you just made a branch on titan bingie mod for matrix instead of maintaining two repos at once. If you are planning on making an actual Kodi Repo for Bingie Mod moving forward I can help you with making a split repo as well from what people have taught me so u can install on 18 and 19 from the same link and get the correct version of the skin.
(2021-04-22, 07:16)Hooacer Wrote: Hi
Thx for skin
Soon
We are almost done but let me see what we come up with. As of now we had to create entirely new add-on for matrix. But I think everything should be in the same repo.
Titan Bingie Mod
Thx for skin
Soon
Do you know any coding like py? That could be of some help.
Titan Bingie Mod
Thx for skin
Soon
New repository will have a matrix and leia branch. At the beginning, only the matrix, because there are changes in the code that are different from leia, but we will also update leia skin . Do not worry. Wink
(2021-04-22, 18:24)AchillesPunks Wrote: Soon
I know a little bit of coding. I just got lost when trying to figure out where to start. If I could figure out where the code begins and where functions start to get called I may be able to figure it out
Hi
Thx for skin
Soon
Unfortunately no sorry I suck, just know a bit of my way around git lol
All good i just wanted to let u guys know in case you weren't aware
@AchillesPunks  One thing I noticed home screen widgets placed very low from middle  and whole area from Clear logo to  spotlight are bigger then widgets area  , can we increase home widgets area a little bit vertically ? and you can see second row almost disappear ? remember its a default setting of current Matrix version.
(2021-04-23, 18:41)nazim12 Wrote: @AchillesPunks  One thing I noticed home screen widgets placed very low from middle  and whole area from Clear logo to  spotlight are bigger then widgets area  , can we increase home widgets area a little bit vertically ? and you can see second row almost disappear ? remember its a default setting of current Matrix version.
If I may answer you. You have that much space because you don't have clearlogo and footer turned on. When it’s all on everything fits almost perfectly.
No, May be it is something related Skin Helper widget because i have enabled all settings but same issue .
 https://postimg.cc/bGss4QjF
Can you share your screen shot ?
  • 187
  • 188
  • 189(current)
  • 190
  • 191
  • 443
