  • 204
  • 205
  • 206(current)
  • 207
  • 208
  • 446
(2021-05-08, 15:24)Giant_Midget Wrote: The Resume playback seems to be working from the Homescreen after the recent Skin Helper Service Widget update. Thanks to whoever fixd that!
We can think @Angelinas for this
Titan Bingie Mod
Thank you for making such a beautiful skin, I have a little problem , the home screen is slow and not smooth , I have a tv box mecool km6 deluxe , thank you again.
(2021-05-09, 07:42)AchillesPunks Wrote:
(2021-05-07, 10:05)Drakens Wrote:
(2021-05-07, 00:33)AchillesPunks Wrote: They do not work in Bingie view
thanks for reply
escuse me , but it doesn't show up in bungie or normal,
you think it's a bug?
its ok for kodi 18 leia but ko for matrix
Let me check
thanks
can you look too,  autocompletion (2.0.1) and global search which doesn't work on bingie mod matrix
doesn't work on windows and android
log:
2021-05-09 12:33:18.589 T:9356     INFO <general>: CPythonInvoker(79, C:\Users\Home\AppData\Roaming\Kodi\addons\plugin.program.autocompletion\plugin.py): script successfully run
2021-05-09 12:33:18.844 T:9356     INFO <general>: Python interpreter stopped
thank you @AchillesPunks
So I now have a full setup on 19 but I used BMC 19 as my base with the skin and it is rock solid.
One thing I id like to know is there a possibility of changing the spotlight and hubs having to use YouTube for look up of trailers if not available in the next update?
The use of API Key 10,000 tokens doesn't even last half the day if trailers are being used.
Is in not possible for the devs to use global search or the skin helper to do the job instead with a bit of coding?
(2021-05-08, 19:50)matke Wrote:
(2021-05-08, 17:56)kingbadass01 Wrote: thank u for make this good skin but, can you plz add arial based font like kodi's default skin?
im using korean, and i cant see any metadata, setting. cuz thats korean.
i only can see squares for each characters.
thanks
Unfortunately this one we use in the skin does not support your language but you can change font to kodi original at any time. It's a little different, it's not in netflix style, but it will serve you. Wink
no. it doesnt serve my language.
this is default fonts
and this is original fonts
thanks
when i use Estuary skin(kodi's default skin) and arial based fonts it serves
(2021-05-09, 10:45)bilalsbz Wrote: Thank you for making such a beautiful skin, I have a little problem , the home screen is slow and not smooth , I have a tv box mecool km6 deluxe , thank you again.
The skin for the most part is based for PC. You can try turning off views that you don't use.
Titan Bingie Mod
(2021-05-06, 20:15)Drakens Wrote: @AchillesPunks
Hello do media flags work on matrix? i try to get them but they don't show up
it's in the OSDPanelBingieview , the mediaflag option is enabled in the settings
thanks
thanks for reply
They show up if you're not in Bingie view. Just hit return one time while paused.
Titan Bingie Mod
(2021-05-09, 15:03)DROIDshield Wrote: So I now have a full setup on 19 but I used BMC 19 as my base with the skin and it is rock solid.
For now you should just create a YouTube API. That will solve the problem.
Titan Bingie Mod
Thanks for the reply. Yes that what I have done but it seems by half way through the day the quota is gone. I just thought there might be another way that could be created to utilise where trailers come from without using YouTube look up and if you had any intentions of moving it from this system.
But okay cool I can disable trailers in spotlight.
Why every time I open Kodi, I see same sequence of movies and tv shows. I mean to say that how can I refresh them so every time I see new one. I have set Oath new movies as my Home like this https://imgur.com/a/aUuDXNA
I have never went through all my trailer quota with a YouTube API. We are talking about all 3 API for YouTube correct. Is your media local or do you stream?
Titan Bingie Mod
(2021-05-09, 22:33)AchillesPunks Wrote: For now you should just create a YouTube API. That will solve the problem.
My media is local .nto and .stm files I believe they are called on my 4 Terabyte drive. But maybe im doing something wrong, you said All 3 API?
I have an api i made, its just one line. That's all I know I've put it into my YouTube addon and it works but pulls for about half a day at constant testing of showing trailers and it quota is gone.
So what is an All 3 API?
(2021-05-10, 03:22)DROIDshield Wrote: Thanks for the reply. Yes that what I have done but it seems by half way through the day the quota is gone. I just thought there might be another way that could be created to utilise where trailers come from without using YouTube look up and if you had any intentions of moving it from this system.
This is what I use and I don't think there is a limit. All three you get when creating a YouTube dev api
YouTube api
Client ID
Client Secret
Titan Bingie Mod
So .nto is associated with TCP correct or am I wrong? And .stm is a stream? So your local media is not in folders with .mkv, .MP4 files? That's how all of mine are so I don't know much about your file types that's why I was asking.
Titan Bingie Mod
  • 204
  • 205
  • 206(current)
  • 207
  • 208
  • 446
