Is there a way to disable all the extra display in the movies / TV shows displays?
I'm talking about recently added, un-watched, genres, studios, etc all the stuff I really don't care, and have just a movie / show list without any sort of buttons, sorting, categories, etc?
It looks like you are using the Estuary Mod skin, so you need to direct your question to the Estuary Mod thread. I will move your thread to the correct forum and hopefully someone can help you further.
Always make sure you ask questions in the correct forum and correct thread.
Well, stop confusing us. Accurate questions lead to accurate answers.
If you check the link I gave you, it allows you to remove the categories on the right of the screen. But you asked a two part question, I am only answering the first part. Your second part and have just a movie / show list without any sort of buttons, sorting, categories
I cannot answer.
very good, thanks a lot! I will look into these two.
ok, so that was a good first step; so, as pkscout said, the only option to have the view below just show the movie list is to use a different skin, right?
