2021-01-15, 20:04
Hehe :-) "mine is even smaller" ...
(2021-01-15, 15:21)graysky Wrote:then you are only building for X11.(2021-01-15, 15:04)wsnipex Wrote: ok, for reference: this is the binary from our ubuntu PPA:
-rwxr-xr-x 1 root root 55M Mai 12 2013 /usr/lib/x86_64-linux-gnu/kodi/kodi.bin
I do not have akodi.bin
but I do have:
Code:-rwxr-xr-x 1 root root 45M Jan 14 13:03 /usr/lib/kodi/kodi-x11
(2021-01-15, 22:56)wsnipex Wrote:(2021-01-15, 15:21)graysky Wrote:then you are only building for X11.(2021-01-15, 15:04)wsnipex Wrote: ok, for reference: this is the binary from our ubuntu PPA:
but I do have:
edit: do you enable ENABLE_APP_AUTONAME?
(2021-01-16, 08:37)wsnipex Wrote: That option is automatically enabled if you only build for 1 windowing system. Any reason you disable wayland and gbm support?
# pacman -S kodi
resolving dependencies...
:: There are 3 providers available for KODI-BIN:
:: Repository community
1) kodi-gbm 2) kodi-wayland 3) kodi-x11
Enter a number (default=1):
docs Wrote:Or configure build with any combination of the three (default is "x11 wayland gbm")
-DAPP_RENDER_SYSTEM=gl
whereas gbm wants -DAPP_RENDER_SYSTEM=gles
. So perhaps I could go from building 3 times to 2 times if I built x11 and wayland with:-DCORE_PLATFORM_NAME="x11 wayland"
-DCORE_PLATFORM_NAME="gbm"
kodi.bin
that is nearly 1 MiB larger. Is there a way to have the build system make two independent binaries?
vs -DAPP_RENDER_SYSTEM=gles
somewhere?/usr/lib/kodi/kodi.bin
so I am wondering how the user can select between say x11 or wayland on a system that has both dependencies installed.
(2021-01-16, 20:28)graysky Wrote: so I am wondering how the user can select between say x11 or wayland on a system that has both dependencies installed.
--windowing=x11|wayland|gbm
(2021-01-17, 00:00)asavah Wrote:Kodi auto detects the correct windowing system at runtime, but you can manually force one by using ^^^(2021-01-16, 20:28)graysky Wrote: so I am wondering how the user can select between say x11 or wayland on a system that has both dependencies installed.Code:--windowing=x11|wayland|gbm
https://github.com/xbmc/xbmc/pull/18534
(2021-01-17, 15:17)wsnipex Wrote: imho, as a maintainer myself: minimalist ppl can build themselves if they don't have a couple MB to spare, while their media takes > hundreds of GB
