I have Kodi running with the default skin. Everything seems to be working fine, but when I pause a video the name/time/ sub options and so on are all partly out of the screen.
I played with settings but can't seem to have it fixed.
Someone any idea what might be the issue?
Klojum
Lost connection
You may experience a feature of your TV which is a souvenir from the past, namely "overscan". The old thick tube TVs from yesteryear used it, and for some odd reason this feature is still available in modern TVs.
Every decent TV should have settings to disable it, although every TV manufacturer has its own name for it. I'd suggest reading up on your TV manual.
Changing settings in Kodi should be your very last resort.
