Release Release 4.1.2
20.03.2021 - Release 4.1.2
+ new columns for HDR and aspect ratio - thx @icebaer72
+ (movies/TV shows) re-added persisting of last used filters #1153
+ (movies) option to only include the first studio in the NFO
+ (movies) added cover.ext to well known poster file names
x removed unused code fot TV show ratings #1233
x display custom rating source logo #1233
x do not delete tags on further scrapes #1233
x (movies/TV shows) saving changed data sources in settings
x (movies/TV shows) do not write NFO on update data sources
x (TV shows) do not strip out TV show title from inside the episode title
x changed renamer token ${hdr} to ${hdrformat}
x better propagation of API errors to the UI #1237
x (TV shows) reworked scrape new items
x (macOS) search for Kodi scrapers in different locations
x (TV shows) writing of correct NFO file name for BD/DVD episodes #1248
x (movies/TV shows) fixed update data sources for git-annex setups #1223
x run some long running actions in a background task
x (movies) sorting of MS/RT columns
x (movies/TV shows) fixed rendering issues of bidirectional text
tinyMediaManager - THE media manager of your choice - available for Windows, macOS and Linux
Help us translate tinyMediaManager at Weblate | Translations at 66%
Found a bug or want to submit a feature request? Contact us at GitLab
Howdy
In some future update, could we get an option under Tv Shows>Trailer settings to automatically save/transfer tvshow-trailer into \Trailers subfolder?
Release 4.1.20
