2021-05-03, 12:58
Hello,
I'm trying to get my AVR (Onkyo TX-L20D) remote to control LibreElec - tested with stable 9 and nightly 10 (20210426). The AVR seems HDMI compliant, I've analysed transmitted frames with cec-client + CEC-O-Matic and all seems fine. Commands from rpi to AVR works (standby, volup voldown etc)
I don't have a TV in my setup , I use a CEC-less dumb monitor (with a touchscreen, unrelated):
rpi2B <-> Onkyo AVR -> Monitor
Only the rpi and the AVR show in cec-client scan:
When trying to control rpi wth AVR's remote, nothing happens. keymap editor addon does not see any incoming keypress either.
Digging deeper:
Here is the complete log when pressing buttons on AVR's remote. (and here on LE10)
See the relevant parts: The keypress form Audio (5) is detected correctly and a
The problem is apparently that
Also note that the log is plagued with a non-existant TV (0), which also shows up in
Is there something I'm missing, or Kodi just plain ignores CEC buttons from Audio ?? It is because I don't have a CEC-capable TV in the chain ?
I've spent last couple of days OCD'ing on this - Read too many posts with similar problems (most unresolved); tested various CEC setting in kodi (setting the connected device to AVR in CEC settings didn't work, nor any port/physical address combination); exprimented with various keymap/remote.xml (no effect at all). Also tested lots of cec related rpi config option in config.txt, checked the AVR's edid... looked at the code of libcec ad kodi... to no avail.
So, any pointers on this would be much appreciated. I'm willing to patch and build/compile if necessary.
CEC bus information
device #1: Recorder 1
address: 1.1.0.0
active source: no
vendor: Pulse Eight
osd string: CECTester
CEC version: 1.4
power status: on
language: eng
device #5: Audio
address: 1.0.0.0
active source: no
vendor: Onkyo
osd string: Sound System
CEC version: 1.4
power status: on
language:
Digging deeper:
PushCecKEyPress
is generated with the correct XINPUT_IR_REMOTE
code. So I guess it gets pushed to m_buttonQueue
here, form my understandig of PeripheralCecAdapter.cpp.Code:
DEBUG: CecLogMessage - >> 51:44:02
DEBUG: CecLogMessage - SetCurrentButton down (2) D:0ms cur:2
DEBUG: CecLogMessage - key pressed: down (2) current(ff) duration(0)
DEBUG: CecLogMessage - Changed key down (2) D:0ms cur:ff
DEBUG: CecLogMessage - key pressed: down (2, 0)
DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:3)
DEBUG: PushCecKeypress - added key a7
DEBUG: CecLogMessage - CheckKeypressTimeout T:3016.037
DEBUG: CecLogMessage - Key down: idle (duration:0) (2) timeout:1782541448ms (rel:161,rep:0,prs:161,rel:0)
DEBUG: CecLogMessage - >> Audio (5) -> Recorder 1 (1): user control pressed (44)
DEBUG: CecLogMessage - CheckKeypressTimeout T:3016.200
DEBUG: CecLogMessage - Key unknown: idle (duration:163) (ff) timeout:1993999652ms (rel:1000,rep:0,prs:0,rel:0)
DEBUG: CecLogMessage - << Recorder 1 (1) -> TV (0): POLL
DEBUG: CecLogMessage - << 10
DEBUG: Previous line repeats 1 times.
PushCecKeyPress
are NOT followed by a HandleKey
event, so they are ignored by Kodi. (Contrary to what should happen as tested here with rpi<->Samsung TV, no AVR).Also note that the log is plagued with a non-existant TV (0), which also shows up in
cec-client -r
. cec-client -r
marks it as 'not present' but I don't see such a message in kodi.log. It may be the cause of interference .Is there something I'm missing, or Kodi just plain ignores CEC buttons from Audio ?? It is because I don't have a CEC-capable TV in the chain ?
