aron Wrote:Try running:
LD_LIBRARY_PATH="/home/atti/libshardy/" ldd /usr/share/xbmc.bin
(xbmc.bin is the real executable)
This will print all the shared library dependencies of the app and the path of the libs. Check that all libraries replaced are found in /home/atti/libshardy/ .
I did the following:
I have dualboot for Intrepid and Hardy, Both has xbmc final 8.1 installed (not the svn)
So far everything works as excepted(Hardy: OK, Intrepid: crap)
I copied the libs related to ffplay from Hardy's partition to a temp dir on Intrepid's partition. I copied most from /lib, some of them i found in /lib/tls/i686/cmov and /usr/lib.
Then i used the magic command:
export LD_DEBUG=files
LD_LIBRARY_PATH="/home/atti/temp/" /usr/bin/xbmc
from the debug i see that xbmc uses ALL the copied libs from Hardy partirion. But... The performance and everything remains the same crap.
I also tried to copy the whole /usr/share/xbmc dir from Hardy partition to Intrepid's. Still no change.
Than i tried to copy the rest of the libs which xbmc uses but ffplay doesn't. It gave me a segmentation fault when i ran xbmc. I removed some of them eg. libc.so.6 libgl.so.1. from the temp dir so that i don't get segmentation fault. But still no change at all. Bad performance on Intrepid.
Now i really don't know what to think where the problem really is. The only thing differs now is the kernel, drivers and some libs and kernel modules. Someone reported to downgrade Intrepid's kernel to Hardy's version with no luck. So we can take out kernel difference. Someone reported the same problem with Intel integrated video. So we can take out nvidia kernel module.
Maybe Aron could help, because he reported to have it working under Intrepid with the lib exchange method i also used. But i don't know why it is not working on mine. Maybe he also did something else which i didn't.
What have i made wrong Aron ? Please help !
