I had the same problem a couple of weeks ago. It fixed itself after a reinstall though.
One question - if your parents internet is that slow - why are they trying to use XBMC to stream TV using iplayer ?
mbc0
Senior Member
Thanks for your replies guys... I will delete that file tonight!
The internet is slow but happily streams iplayer & Plex but it is quite painful using Teamviewer (even on lowest settings) Thankfully they never have streaming issues, even in HD!
2014-03-10, 13:18
(This post was last modified: 2014-03-13, 01:16 by gott_sei_dank.)
Missing Episodes
Episodes 3 and 4 of Permission Impossible are missing (from get_iplayer too), but are available from the web site.
edit: Not sure why it is was available on the web, but it looks like BBC Wales is out of synch not sure why they don't just leave the episodes up till Wales catches up.
Hi guys,
Newbie XMBC user here with a question about the iPlayer plugin (great work by those responsible, by the way!).
I note that the BBC is about to launch a new version of iPlayer. Will the current XMBC plugin still work when the new version is launched, and is anyone working on an upgrade to the plugin to reflect the new BBC version?
Hitcher
Team-Kodi Member
I guess no-one will know until it's released.
RIP Iplayer addon ? Seems to be down since this evening, I wonder if this coincides with the new look ?
Hitcher
Team-Kodi Member
I thought old look was bad the new one is terrible!
mbc0
Senior Member
Mine is still working fine....
Seems to be working again this morning.
Sorry in advance for a real newbie-type query here.
I have successfully installed the latest iPlayer plugin with Frodo and the video seems to stream just fine. However, every stream I play shows as "SD" in the menu display of the player. I have everything set to default (including "auto" for video streams) and I am running a wired connection. Am I doing something wrong? Or does the iPlayer plugin in fact stream in HD when available and just not say so in the menu display?
