Kaaino
Junior Member
2010-08-11, 21:35
(This post was last modified: 2010-08-11, 21:44 by Kaaino.)
Hi, I have tried to use the plug in with XBMC builds from SVN ppa. However it seems that the ppa builds do not have rtmp support.
Where can I find a different linux build that works?
There is also a version 2.2 available now. With this, do you still need the get_iplayer workaround for windows. With Camelot you still need the workaround, but have not yet tested with newer releases.
Hitcher
Team-Kodi Member
@ exobuzz
XBMC Addons use major.minor.micro for the versions.
I have uploaded a new version which may solve some issues some people were having (or not). there were a couple of bugs when installing the plugin/addon for the first time
garyi
Posting Freak
Sio if I can find build r32234 and the latest iplayer I might get further than script error?
the script error is unrelated. however if you have the script error you might want to try the latest plugin version i uploaded earlier.
garyi
Posting Freak
I did. It does not work.
To be clear I don't get anywhere into the plugin. I select iplayer from the video addon menu and it immediately says theres a script error. I have tried on three different macs and ATV
post a bug report on the iplayerv2 google site ?
