without the workaround i would think. the plugin is designed to work with the dharma versions of xbmc that include new librtmp functionality.
2010-08-18, 13:44
(This post was last modified: 2010-08-18, 13:47 by exobuzz.)
Download an svn build with revision 32756 or greater. if you are using a dharma branch, you need to check if that has been merged into dharma and at what point. I can't advise further as I don't know what platform you are running on, and I only run xbmc on linux (and xbmc4xbox on xbox)
Smiff
Senior Member
sorry is there a changelog for this plugin anywhere?
i just don't know whether to update or not
Thanks Kaaino. Followed your instructions and got Hitcher's addon working.
Great! Compared to the get_player wordaround this loads in 5 sek versus 20 sek, and Live TV works. Thanks everyone involved for this I know that many have contributed.
But I do now have problems though with e.g.: "Remote share: Could not connect to network server" when trying to start the YouTube or Apple Movie Trailers Lite plugins. Can hardly blame the iPlayer addon, but rather svn 32869. I have had this problem before when trying anything newer than Camelot. Advice!?
Hitcher
Team-Kodi Member
Please note it's not my addon I simply host it to make it easier for everyone to get the latest version.
garyi
Posting Freak
I am getting regulary funk behaviour.
It all seems to be running fine then the stream will abruptly end and return to the menus.
I can only assume some sort of stream error but sadly no error is giving, it just returns to the menus as if its finished.
Is there a way I can diagnose whats causing this?
tried with debug log on?
Can try a different stream source also in the plugin settings. I find akamai works best for me
garyi
Posting Freak
I assumed the settings meni did not work, turns out it does not work in elipsis. So now I see lots of settings! Will have a play.
Uuaww
Senior Member
any chance this will be supported in british virgin islands?
You may need to use a proxy or vpn (Are you able to use the iplayer website?). There are hacks to add proxy support to the plugin, i have not integrated it yet as a official feature. If you have a vpn to the UK, it should just work.
Am wondering if I'm doing something simple wrong. Downloaded the latest svn Linux build from ppa and installed the plug-in but get error: script failed
please post a debug log. you can alternatively open an issue on the google code site (including the log).
