Same problem here too - configured UK proxy in Settings>network and tested access using a PC and it works fine - but iPlayer Video Plugin shows the show, then says Error Fetching Media Info and then it tries to play the Video Stream and throws a script error.
I guess the iPlayer plugin is broke
how do i install iplayer? with dharma everything is different and i just install plugins from the add on library now, how can i install this? can anyone give me a step by step? i use dharma rc1 at the moment
Hitcher
Team-Kodi Member
Or follow the instructions in my signature.
Can any one help I get a script failed message when I try and use the Iplayer addon. This is what is in the debug log. Any help is appreciated
ERROR: Error Type: exceptions.Exception
18:05:37 T:2859625328 M:1629405184 ERROR: Error Contents: Could not get AddonPtr!
18:05:37 T:2859625328 M:1629405184 ERROR: Traceback (most recent call last):
File "/home/charles/.xbmc/addons/IPlayer/default.py", line 22, in ?
import addoncompat
File "/home/charles/.xbmc/addons/IPlayer/lib/addoncompat.py", line 15, in ?
__addon__ = xbmcaddon.Addon(os.path.basename(os.getcwd()))
Exception: Could not get AddonPtr!
18:05:37 T:2859625328 M:1629405184 INFO: -->End of Python script error report<--
18:05:37 T:2859625328 M:1629405184 INFO: Python script stopped
18:05:37 T:2859625328 M:1629405184 DEBUG: Thread 2859625328 terminating
18:05:37 T:2751527792 M:1629405184 DEBUG: WaitOnScriptResult - plugin exited prematurely - terminating
18:05:37 T:3021961088 M:1629405184 ERROR: GetDirectory - Error getting plugin://plugin.video.iplayer/
18:05:37 T:3021961088 M:1629405184 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.iplayer/) failed
Hitcher
Team-Kodi Member
How have you installed it?
I downloaded the zip then in addons used the add addon from zip option hope that helps
Is the developer still active?
Is there anyway that the app can be updated to allow a proxy server to be set?
It's fine for people in the UK but for us ex-pats, we can watch through a proxy on the PC but have never been able to get XMBC (on the AppleTV at least) to recognize a proxy.
I'd even be happy to support a developer through a PayPal donation to get this working.
Sorry if this is a little off topic but does anyone know if there is a 4OD plugin available for XBMC?
