spiff
Team-Kodi Member
doubt it. way too memory intensive. whatever arnova decides ofc
spiff
Team-Kodi Member
who knows. i'd say it will probably be up to the skinners.
xbox is simply no concern of ours these days. this is the perfect example why; having to keep it compatible hurts the other platforms.
Hitcher
Team-Kodi Member
At least with Aeon you can revert back the changes made for background downloading (even though it's not officially supported for the Xbox).
spiff
Team-Kodi Member
2009-06-15, 17:56
(This post was last modified: 2009-06-15, 17:58 by spiff.)
WAY to rip information out of its context roonie. well done.
as jmarshall points out, it will use MORE memory during transitions. having to keep another texture + its decode buffers in memory during transitions will/can surely be the big bad for the xbox, in particular in high resolutions.
believe it or not, i'm not entirely clueless and i wouldn't put that unless i actually knew what this involves! oh, and for the record; the context i'm refering to is that is jmarshall's answer to the question 'will background loading lower the memory usage on xbox'.
that being said, i was obviously wrong on the port status of the code. guess arnova chose to add it
MiniMeedia uses background loading for the fanart and custom background images and seems to work fine on the xbox.
Follow development of MediaStream, MiniMeedia and other skins on Twitter (@skunkm0nkee)
