Im using this on the appleTV. Any while this performs far better on the appleTV than aeon, browsing the movies section (Im using library mode, don't know if there is a difference with Library mode turned off.) is very sluggish. Not sure what is causing it. I've disabled everything I can think of to disable. Downgrading the background images to 720 helped a fair deal, but not enough. Any suggestions? If performance were to improve, I'd be willing to switch to xbmc full time, away from my appleTV interface. Something I want to do so I can stop running iTunes 24/7
xbs08
Posting Freak
Have you tried 960*540?
xbox users say this improves performance maybe it improves on ATV too.
- Intel NUC Kit DN2820FYKH ~ Crucial DDR3L SO-DIMM 4GB ~ SanDisk ReadyCache 32GB SSD ~ Microsoft MCE model 1039 RC6 remote
xbs08
Posting Freak
2009-07-18, 12:24
(This post was last modified: 2009-07-18, 12:26 by xbs08.)
i meant the player controls... can you pull them on the Xbox?
On the PC press "M" and you'll see what i mean.
Waffa
Posting Freak
Hmmm you're right.
Must be in the keymap.xml have a look to it.
Waffa
Posting Freak
2009-07-18, 13:00
(This post was last modified: 2009-07-18, 22:58 by Waffa.)
Ok here it is.
Add this line in your keymap.xml / <MyMusicLibrary> / <remote> (line+- 451)
Or change in global whatever...
<menu>ActivateWindow(PlayerControls)</menu>
Why:
Your keyboard has <m>ActivateWindow(PlayerControls)</m> in Global.
Your remote not !!! <menu>PreviousMenu</menu>
xbs08
Posting Freak
MM and media flagging don't seem to get along on slow CPU's.
Check the CPU usage in movie library.
Just being curious.... Any news on the next version?
XBMC Main HTPC:
Asrock ION 330 running Openelec 3
XBMC 2:
XBMC Frodo running on OSX 10.8 (Core i7, Hackintosh)
XBMC 3:
XBMC Frodo running on OSX 10.8 (2011 iMac)
Server and TVHeadend backend: Ubuntu 12.04
