Bomb Bloke Wrote:As mentioned, if you play a video with DVDPlayer - which is incorporated by the Xbox version of XBMC - the media flags for that particular video will be extracted. Granted, it won't extract the things automatically for all your videos (this apparently caused stability issues in low-RAM environments (eg HD)), but the functionality is there.
Ok thanks, that i don't understand is that the option who where before on the VIDEO SETTING has been removed, we can't check it or not check it
It is very strange ...
Before, after the SCRAPER finish scanning, we go to a folder, XBMC extract the FLAG of all the videos of the directory ... if now we must read all the video one by one to make it it will be so long
You are real for the RAM problem, yes when the xbox extract flag you must do nothing ... because if you move in the menu or other thing XBMC will freeze ... but it is not really important, we not scan our folders every days ... when the DB have the information XBMC not scanning again.
Bomb Bloke Wrote:Your cache settings can be changed via "UserData\AdvancedSettings.xml". A template of this file, which includes sample lines for dealing with cache settings, exists in the UserData folder of current builds.
Ok thanks for the information.
I will go to change it myself, but why the config screen has been removed ?
It is stupid to do something by FTP on PC, it is longuest than make it directly on our TV with XBMC
Will some solutions will come for these two xbox problems ?
