Janny
Junior Member
I carried on digging. The reason your suggestion worked is that the nightly build installer comes with system\players\dvdplayer\avutil-49.dll but the nightly build patch "Windows Archive" comes with system\players\dvdplayer\avutil-50.dll.
Guess it's just a case of updating the installer to package the correct dll avutil-50.dll).
fnwc
Senior Member
Curiously, does anyone else notice that the "media" folder on the nightly build is now called "mediza"?
any1 got a newer win32 dx build than camelot alpha2 for me?
Insem
Junior Member
Hi There
Just want to make sure I get this right before I go and screw something up again.... I am running a older dx version of the Nightly build on my win7 32 with intel graphics its the only one I have got to work with the Aeon Showmix,,,,, I would like to upgrade my nightly build to be the latest one, to do this do I just download the new build, copy and paste into c:/progfiles/xbmc folder replace the files and done ?
AzzX
Senior Member
Installing over the top works for me, just backup your xbmc user folder - usually in C:\Users\XXXXXXX\AppData\Roaming\XBMC
Insem
Junior Member
Thanks AzzX
Ill try it tonight
2010-09-01, 18:01
(This post was last modified: 2010-09-01, 19:30 by ingeon.)
Using xbmc-r33324-Dharma_beta1(exciting) on WinXP_32. So far looking good!
I found that if you listening to music with the milkdrop visualization on and you minimize that XBMC goes black and stays like that until you kill&restart. DirectXspectrum works fine, waveforms shows nothing, can`t see big difference in log.
Anybody else same experience?
Hardware:
22:12:41 T:3348 M:2636042240 NOTICE: Intel® Core2 Duo CPU E8500 @ 3.16GHz
22:12:41 T:3348 M:2636038144 NOTICE: Desktop Resolution: 1280x1024 32Bit at 75Hz
22:12:41 T:3348 M:2636038144 NOTICE: Running with administrator rights
22:12:41 T:3348 M:2635751424 NOTICE: Found screen: Default Monitor on NVIDIA GeForce GTX 260, adapter 0
Kodi - Windows 7_x64 14.2 Helix
OpenELEC - Generic x86_64 v5.0.8
OpenELEC - Raspberry Pi2 v5.0.8
Ember media manger 1.3.0.20 (thx DanCooper)
Media Companion v3.620b (thx Vbat99)
Rashad TVRenamer 0.7 Beta 2/EPnamer v1.45
Calibre-ebook
CrystalP
Team-Kodi Developer
Ingeon, can you start a new thread in the Windows forum with this problem.
I have an idea why that happens, I'm just surprised the two other vizes work fine.
And please include a complete debug log.
