2011-12-16, 05:35
Hi Guys,
for those that have noticed, there is another update for the skin in the Passion repo.
Good news is that the horizontal home menu is back. Horizontal home menu is pretty well in it's final form (may add watchlist script support). Navigation is a little different to before. Now to get to the recently added icons on the shelf, just go up until icons hilite. You can select and play any of these icons. Also to move to a different menu you move left/right and then up/down within each menu. For the AppleTV gen2 crowd, this menu is now 99% of what it is on the AppleTV, so take it for a spin and see what you think.
From this point on, unless you can make a really good case for it, I will not add any other features for this release. Bug fixes only from now on.
Good new also for the XBox crowd, have started porting the code to the XBox. Hope to have something available thru my SVN before Christmas. As I no longer have a XBox for testing I will be relying on you guys to find and report any problems. So basically the quality of the skin on the XBox is dependant on you and your bug reports. A good idea of what I will need is provided by most of Lipo's bug reports. So a FULL debug log, screen grab and a short description of the problem (one problem to each debug log if you can please, as huge debug logs are no fun to wade thru). Also Please do NOT post partial logs directly to this forum, use pastebin.com (or something similar) and paste the address to the log file into your post.
AGAIN I repeat please post ALL of the FULL log file as there is important information in this file that will help pin down problems.
Enjoy
Wyrm (xTV-SAF)
Enjoy
Wyrm (xTV-SAF)
