  • 32
  • 33
  • 34(current)
  • 35
  • 36
  • 116
[Web Interface Addon] [Eden] XWMM - XBMC Web Media Manager
slash Wrote:jjrroberts,
Thanks for the good comments on XWMM.
I thing what you want is a way to filter the tree view to see only the unscraped movies/episodes.
If this the case, there is already a feature request for global filtering in the file view and I'm working on it. It's pretty hard to do so it will take some times.
Thanks for your understanding.
That sounds perfect Big Grin
Thanks again for your efforts
Hi Flomaster,
After adding from zip file, you should :
sudo cp -R /usr/share/xbmc/web/XWMM [b]/usr/share/xbmc/addons/webinterface.default/XWMM[/b]
should work after that.
let us know, I might have to update the instructions
Addons will be installed to "~/.xbmc/addons/" or am I wrong?
Not sure ...
I'll do a full test this week-end.
BurningSky Wrote:Addons will be installed to "~/.xbmc/addons/" or am I wrong?
Just finish a test install and you are right. the addons are installed in "~/.xbmc/addons/"
Do you think it could work on AppleTV? Enough CPU power to run this?
so whats the verdict on the proper way to install this, ?
-=Jason=-
Removed!
I found the feature that i was requesting!
Nice work Smile
Flomaster Wrote:so whats the verdict on the proper way to install this, ?
-=Jason=-
After installing the package :
sudo cp -R ~/.xbmc/addons/webinterface.XWMM /usr/share/xbmc/addons/webinterface.default/XWMM
Hi all,
New version available 1.9.1 only fixes :
- Fixed genre list display was not always showing
- Fixed movie information not always showing
- Fixed changing covers and fanart in movies
You can download it from the first post or wait the add-on update from the repository Wink
Let me know
slash Wrote:After installing the package :
Fak, me what repo is this on, stock xbmc one or a custom one?
-=Jason=-
If you are using a very recent SVN build (more recent than Dharma Beta 2) you can use the XBMC official repository (look into settings / Add-ons / install add-ons / XBMC repository / webinterface).
If you are using Beta 2 webinterface plugins don't show in the list and you will need to download the zip file and install it with (settings / Add-ons / install from zip file).
Hope this help.
XWMM latest SVN is now available via :
http://xumm.svn.sourceforge.net/viewvc/x...face.XWMM/
current SVN is 1.9.2-pre (revision 6)
So there is the official XBMC add-on repository that will contain the XWMM latest stable version and the SVN version directly from sourceforge.
Any idea how users can install directly from the SVN ?
ok updated to svn 34731 I'll check the repo when I get off work
and for SVN updating check it out here
http://git.or.cz/course/svn.html
-=Jason=-
ok I finally have this working...
I did a fresh install of xbmcfreak beta3 wiped my hard drive and figured i'd give this a another go.
I installed from the addon repo and had to run this command
-=Jason=-
  • 32
  • 33
  • 34(current)
  • 35
  • 36
  • 116
[Web Interface Addon] [Eden] XWMM - XBMC Web Media Manager8
