2010-05-18, 03:44
kvandesteeg Wrote:Got it version 444 working from the command line.mythicalSetup will now work just fine. It is set for default now at ~/Episodes ~/Showings and ~/Movies
I gave up on the setup script - the filesystem test was failing because of running the script under sudo su
running the diagnostics under sudo, it worked as expected
i also had to add mysql's path to /etc/profile
Now that it's working ... how do i change it?Code:PATH="/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/mysql/bin"
specifically for movies, i don't want directory/movie title/movie title(year).mpg i'd rather have directory/movie title (year).mpg
Was that just because i ran it from the command line?
I haven't seen the output from a live recoding from MythTV yet.
I haven't gotten the RSS fixed yet, but i'm using mythweb's rss feed for now.
