2010-09-07, 01:27
The first thing I noticed is that the permissions are wrong in your recordings dir.
Here is my mythtv recordings dir. At a minimum you must have RW access. I have not modified the permissions in this folder at all. This is default and normal. I also noticed that there are no pictures to go with your
Your permissions look like you chmod 555'd it. It should be 666'd. There is no write access in that folder, but every file is readable and executable which makes no sense for media files.
Make sure that mythtv is in the Robot group. I'm actually not sure why, but even the owner isn't allowed to do certain things unless they're a member of a group.
Is it just that one entry that does not have any "new search initiated"? the next entry has it. It could have been that the updater was activated in the middle of mythtv processing the file so the log was dumped into the old log. Can I see the next entry? I would like to get more information. I'm getting ideas as to how to properly handle this, and I believe this setup issue could be handled autonomously in mythicalSetup.
-rw-rw-rw- 1 mythtv mythtv 14731 2010-09-04 18:15 1952_20100903100000.mpg.64.100x75.png
-rw-rw-rw- 1 mythtv mythtv 118677 2010-09-03 10:52 1952_20100903100000.mpg.png
lrwxrwxrwx 1 mythtv mythtv 138 2010-09-06 07:26 1952_20100906063000.mpg -> /home/mythtv/Videos/Episodes/Clifford the Big Red Dog/Season 2/Clifford the Big Red Dog S02E01 (Cliffords Valentines Day Special 2002).mpg
-rw-rw-rw- 1 mythtv mythtv 101323 2010-09-06 07:25 1952_20100906063000.mpg.png
lrwxrwxrwx 1 mythtv mythtv 124 2010-09-06 07:30 1952_20100906070000.mpg -> /home/mythtv/Videos/Episodes/Curious George (2006)/Season 5/Curious George (2006) S05E01 (George and Marco Sound It Out).mpg
-rw-rw-rw- 1 root root 114387 2010-09-06 07:30 1952_20100906070000.mpg.png
drwxr-xr-x 16 mythtv mythtv 4096 2010-09-06 18:00 Episodes
drwxr-xr-x 2 mythtv mythtv 4096 2010-09-06 18:00 Movies
drwxr-xr-x 13 mythtv mythtv 4096 2010-09-06 18:00 Showings
sudo chmod 666 /var/lib/mythtv/recordings
sudo useradd -G robot mythtv
