2012-02-29, 15:19
Well no, i also have made a widget remote for Android (check my signature) but it does not include full browsing.
Tolriq Wrote:Well Yatse load the Fanart that Xbmc send.
So if no background is loaded that means that Yatse don't have informations about it and so can't load it
(2012-07-15, 10:11)o0oFoXo0o Wrote: Hallo.
Iam using YATSE2 with XBMC Eden on a Silverstone SST-GD02S-MT with 4.3" TFT touch-screen display.
First of all : I LOVE YOUR PRODUCT!
Actually iam not controlling my HTPC with your software. It only needs to show video information like the movie/tv-show currently playing.
And its doing a great job. Except when the movie/tv-show stops (manualy stop or it just ends) it stays at the "information" screen.
Is it possible in case of stoping (not pause) a movie/tv-show to bring it back into the "main screen"?!
You already said it should work but its not. After stoping the playback the screen for a sec goes black so i guess YATSE2 recordnized
something. But after that it shows the same media information screen like it did in playback and sadly NO main screen...
Thankful for your help.
(2012-07-15, 11:18)Tolriq Wrote: @adelphia : not yet, since no answer did not take time to check more about licensing and so. But I'm not using any Imon or specific touch screen API code.
@o0oFoXo0o : right now I'm full time one Yatse for Android but I'll check this bug as soon as I've more time.
@e2zippo : wrong thread :p this is Yatse for Windows here
(2012-07-15, 12:36)Tolriq Wrote: Hum users know better my soft than me :p It has been too long since I work on Yatse 2:p
For LCD I just treat it as a secondary screen and use standard mouse input.
But Montellese had make a good job for using real imon API : http://forum.xbmc.org/showthread.php?tid=84166 perhaps you'll find all you need there.
(2012-07-15, 11:18)Tolriq Wrote: @e2zippo : wrong thread :p this is Yatse for Windows here
(2012-07-15, 12:15)adelphia Wrote: I can answer this one for you as I had the same issue. There is a setting in YATSE.xml (<GoHomeOnEndPlayback>false</GoHomeOnEndPlayback>), Change false to true and it will go back to the home page when it finishes playing.
