  • 42
  • 43
  • 44(current)
  • 45
  • 46
  • 55
Win Yatse 2 : Open Source Media Center Remote Control App for Touch Screen
Well I suppose you talk about Yatse for Android and not this Windows version Smile
And for the disconnect as usual without logs and details I can't tell http://yatse.leetzone.org/redmine/projec...wiki/Debug
Only reports I have is that there's some raspbmc release that are bugged and have faulty webserver embed.
I'm still using this mainly as a metadata display on my HTPC case monitor and it's been fine until Gotham.
Can't get a connection to XBMC and just wondered if there was any possibility to patch it to work?
(2014-08-03, 06:12)phsyraxion Wrote: I'm still using this mainly as a metadata display on my HTPC case monitor and it's been fine until Gotham.
Nevermind. All seems to be working.
I was having an issue with Yatse locking up when trying to connect to a running XBMC v13 session. What I needed to do was delete the Yatse.db file and reconfigure a connection from scratch and all started working again.
Hi Tolriq,
I'm using Yatse for quite a long time to display info on the second screen and it works really great. I have only one problem: I'm using Gotham 13.2 and while playing music the cpu is high. If playing a video it's normal. Can you help me to find out what the reason is?
Hi got Gotham 13.2 installed on Win7 64bit and HTPC with TFT 800x600 display.
Many months I have used the YATSE2 for windows to display information during playback a movie. But after Changing the local database to MYSQL database the display don't shows the fanart and info during playing. So no NOW PLAYING information...
Any one can help?
Thanks for help.
Thanks so much for your contributions to Yatse2.
I use Yatse2 on my 7" touchscreen display on my HTPC case (as Secondary Windows 8.1 Monitor). I noticed when my PC is completely idle for a long time, Yatse prevents the monitors from going into Sleep mode (even though there is no media playback... Yatse just sits on the Weather Forecast screen on my second monitor).
Is there any way for Yaste2 to do what it's supposed to without interfering with Windows Display Sleep Power options when the PC is completely idle?
Maybe there's a hack/work-around if there isn't any builtin support to avoid this?
To be honest I haven't look at the code from Yatse 2 for years Sad
I don't even remember how most of the things work in it.
Thanks for the quick reply Tolriq, I really would appreciate it if you could take a look. I just donated to the project yesterday; and, willing to donate generously again just to fix this issue with Yatse (to allow Windows Power Savings to put it's Monitors to sleep mode).
I currently have to turn off (and on) both of my LCD monitors at least twice a day; which is very tedious. Thanks again for all your effort. This is an irreplaceable addon!!!
(2015-04-01, 10:12)Tolriq Wrote: Hi,
This looks like an awesome piece of software for those with HTPC with touchscreens. Is the Windows version still available for download somewhere?
Sorry for the moment only source code : https://github.com/Tolriq/Yatse2 is available.
Last server crash and I still had no time to restore everything needed, and to be honest I'm not sure I'll spend time on this due to everything being old and unmaintained Sad
I've spent a lot of time; but haven't found any software that can replace Yatse2. It's basically irreplaceable. I actually completely depend the information it displays (on my 7" LCD touchscreen on my HTPC case).
I have a copy of the latest Yaste2 installer below. I don't have any issues with it at all. I used to think it was causing problems with Windows Power Saving; but, it looks like the problem was something else on my system.
Yatse2 Installer Download Link:
http://1drv.ms/1yOhHr3
(2015-04-21, 17:42)MKANET Wrote: I have a copy of the latest Yaste2 installer below.......
Hey, thanks for the link. Although after I download it and run the application it gives me an error message of "yatse website down". I'm guessing that it was trying to download the rest of the application from the now defunct website?
I don't suppose that anyone has a full copy of the application that they can upload for sharing?
(2015-04-21, 09:29)Tolriq Wrote: Sorry for the moment only source code : https://github.com/Tolriq/Yatse2 is available.
Thanks for the reply. Although I wouldn't know where to begin to compile this source code into an executable software! Any pointers gratefully accepted!
Ohoh.. that got me worried. I'm pretty sure that's what I used to install it. I do need a way to reinstall it if I need to. Maybe, I can just zip up my program directory for you?
Yes you can zip and backup the folder it will work on any installation as it's portable.
Here's a portable version below. Just unzip to Program Files or C:\Program Files (x86), run executable, and configure. Remember to enable the http interface in Kodi (under Settings\Network\Webserver\Allow Control of Kodi Via HTTP).
Download Link:
Yatse2 Portable
  • 42
  • 43
  • 44(current)
  • 45
  • 46
  • 55
Yatse 2 : Open Source Media Center Remote Control App for Touch Screen5
