(2015-06-30, 10:49)billybob69 Wrote: (2015-06-29, 00:02)GlennNZ Wrote: You need to install the whole program setup file and the then update(s) over the top if needed/any. (Not just the 413kb update file as you appear to have done)
I defo installed both files and not just the 413kb file. I think that I installed the service.setup file first followed by the socket file - as per the instructions pdf. If this was the wrong way around, perhaps it might be helpful to updated the pdf?
Anyway, installed 121 build successfully and all seems to be working well.
Couple of points; it might be worthwhile to set it as 'Open Yatse on Secondary Screen' as true by default, as initially I couldn't figure out why Yatse wasn't showing on my HTPC screen.
For anyone who installs Yatse for the first time, it might be useful to understand that it does take a while to download all the fanart and that it is still downloading the fanart when there is an hour glass next to the remote icon.
Is the Yatse window supposed to reduce in size when on the HTPC / secondary screen and I have increased the DPi on the main screen? It doesn't at the moment. No bother if it isn't supposed to, as I am more than happy with where we have got it now!
Cheers,
bb69
Thanks - the earlier builds didn't close very well and could cause problems if auto start with windows was enable and tries to run a few builds - that may have been the issue. The install pdf is right - well not right or wrong shouldn't matter which one is installed first. Nonetheless - Good to here all working well.
Re: open second screen as default
yes that was default but changed it based on your issues because if have issues with second screen then very hard to troubleshoot if can see screen or doesn't open at all. Figured better to start first screen setup and then move over.
Re: dpi settings
I believe dpi settings are system wide rather than one Screen at a time. (Although haven't looked this up)
The 121 setup includes a registry change to run the yatse Exe without changing for the dpi - but this was dependant on a few factors (name, install location etc) and may have not stuck with your install.
try the method a post or two above right clicking on yatse Exe in its directory and change the compatibility settings as I indicated above.
That should run yatse at the correct resolution/Dpi regardless of what screen it's on. (Or turn dpi off - can cause similar issues with multiple apps)
Hope the fanart browsing is working well.
All the best
Glenn
