  • 10
  • 11
  • 12(current)
  • 13
  • 14
  • 55
Win Yatse 2 : Open Source Media Center Remote Control App for Touch Screen
Are you using HTTP or JSON ?
I've restarted to work more on Yatse, curently implementing Audio.
Will try last XBMC builds to make the necessary changes for next alpha.
Sorry for the delays but real work have over occupied me Sad
Using http, do you have a recommended build i should use in the mean time? Then again with you starting work on it again- maybe i'll hold off Smile
I use 9.11 and 29202 for tests.
Will try the lasts builds and to upload a refresh of alpha with preliminary audio support on sunday max Smile
As promised, a refresh of Pre Alpha Smile
Please do a fresh install or delete your Yatse2.db as the database as changed and i won't handle upgrade path for alpha Smile
There's a lot of change in the back office for more stability and near full audio support (missing song view handling will probably only be as some kind of info popup on album view).
The designs of the Audio browse view may change in future builds.
This build still lacks Tv Shows supports.
This build should work for any XBMC >= 9.11 (tested up to : build 30655 )
Even if alpha please upload logs and reports major problems to reduce the alpha and beta cycle to it's minimum Smile
Next build should be a real alpha with all functions included.
Does many of you use banners for tv shows and seasons ? (or fanart type image ?) instead of classical thumbs ?
Thankyou Big Grin, I'll test it soon!
As far as TV shows go- Posters all the way for me..
Edit: Nevermind
Downloaded it already, but still unable to test, since my *%&X ... grrr .... Touchdisplay driver still makes problems .... updated driver are worse then the old ones ... soundgraph ... :-( ....) ...
to be continued ....
Hum can you please remember me what the problem is ? Smile
Great to see that the project is alive!
Currently testing the new Beta. When skipping to the next track in an album. Yatse says: "nothing" and goes back to the home screen. At the end of a track within an album. I get the same message: "Nothing" and Yatse returns to the home screen.
@Tolriq Are you a fan of Spotify? Would be great to have that implemented in the (far) future.
@matrixxx : The nothing and return to home is when there's nothing left reading on xbmc.
Can you please upload the log file to see if Yatse queue correctly all the album songs ?
Below the log of starting the Album of Amy Winehouse back to black and skipping from "Rehab" the 1st track to "You know I no good" the 2nd track
[17:21:32.5783] Yatse2        : Starting
[17:21:32.7833] Yatse2        : End load config
[17:21:32.9203] Yatse2        : Load dictionaries - Skin : Default, Lang : English
[17:21:33.3463] Yatse2DB      : Opening database : E:\Arthur\Downloads\Yatse\Yatse2-Alpha-Refresh\Yatse2\Yatse2.db
[17:21:33.4123] Yatse2DB      : Query : SELECT MAX(Version) FROM `Version`;
[17:21:33.4243] Yatse2DB      : Query : SELECT * FROM `Remotes` WHERE Id = @idRemote;
[17:21:33.4263] Yatse2DB      : Param : @idRemote=1
[17:21:33.4323] Yatse2        : Init remote : 1 - Athlon
[17:21:33.4333] Yatse2Api-XHT : Configure : 127.0.0.1:
[17:21:33.4343] Yatse2        : Init Timer
[17:21:33.4363] Yatse2DB      : Query : SELECT * FROM `Remotes`;
[17:21:33.4433] Yatse2        : Refresh weather
[17:21:33.4733] Yatse2        : Dispay settings changed
[17:21:33.6004] CurrentResolutionMonoScreen : <Devmode>
  <DMDeviceName>cdd</DMDeviceName>
  <DMFormName>&#x1;&#x4;&#x1;&#x4;|</DMFormName>
  <DMSpecVersion>0</DMSpecVersion>
  <DMDriverVersion>0</DMDriverVersion>
  <DMSize>0</DMSize>
  <DMDriverExtra>0</DMDriverExtra>
  <DMFields>0</DMFields>
  <DMOrientation>0</DMOrientation>
  <DMPaperSize>0</DMPaperSize>
  <DMPaperLength>0</DMPaperLength>
  <DMPaperWidth>0</DMPaperWidth>
  <DMScale>0</DMScale>
  <DMCopies>0</DMCopies>
  <DMDefaultSource>0</DMDefaultSource>
  <DMPrintQuality>0</DMPrintQuality>
  <DMColor>0</DMColor>
  <DMDuplex>0</DMDuplex>
  <DMYResolution>0</DMYResolution>
  <DMTTOption>0</DMTTOption>
  <DMCollate>0</DMCollate>
  <DMUnusedPadding>0</DMUnusedPadding>
  <DMBitsPerPel>32</DMBitsPerPel>
  <DMPelsWidth>1280</DMPelsWidth>
  <DMPelsHeight>1024</DMPelsHeight>
  <DMDisplayFlags>0</DMDisplayFlags>
  <DMDisplayFrequency>60</DMDisplayFrequency>
</Devmode>
[17:21:33.6014] ChangeResolutionMonoScreen : <Devmode>
  <DMFormName />
  <DMSize>0</DMSize>
  <DMPelsWidth>800</DMPelsWidth>
  <DMPelsHeight>600</DMPelsHeight>
  <DMDisplayFrequency>56</DMDisplayFrequency>
</Devmode>
[17:21:33.6014] Yatse2        : End init
[17:21:34.4474] Yatse2        : Home Page : grd_Home
[17:21:35.4635] Yatse2        : Remote connected : 1 - Athlon
[17:21:36.4825] Yatse2DB      : Query : SELECT * FROM `AudioArtists` WHERE IdRemote = @idRemote ORDER BY Name;
[17:21:36.4825] Yatse2DB      : Param : @idRemote=1
[17:21:36.5095] Yatse2        : Show Grid : grd_AudioArtists
[17:21:45.9521] Yatse2DB      : Query : SELECT * FROM `AudioSongs` WHERE IdRemote = @idRemote AND IdArtist = @idArtist ORDER BY IdAlbum,Track;
[17:21:45.9521] Yatse2DB      : Param : @idRemote=1 , @idArtist=7
[17:21:45.9771] Yatse2Api-XHT : COMMAND : ClearPlayList(0)
[17:21:46.0331] Yatse2Api-XHT : COMMAND : PlayFile(E:\Liesbeth\MUZIEK\Amy Winehouse\101-amy_winehouse-rehab-ukp.mp3;0)
[17:21:46.0661] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\102-amy_winehouse-you_know_im_no_good-ukp.mp3;0
[17:21:46.0881] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\103-amy_winehouse-me_and_mr_jones-ukp.mp3;0
[17:21:46.0961] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\104-amy_winehouse-just_friends-ukp.mp3;0
[17:21:46.1141] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\105-amy_winehouse-back_to_black-ukp.mp3;0
[17:21:46.1281] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\106-amy_winehouse-love_is_a_losing_game-ukp.mp3;0
[17:21:46.1441] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\107-amy_winehouse-tears_dry_on_their_own-ukp.mp3;0
[17:21:46.1611] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\108-amy_winehouse-wake_up_alone-ukp.mp3;0
[17:21:46.1781] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\109-amy_winehouse-some_unholy_war-ukp.mp3;0
[17:21:46.1941] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\110-amy_winehouse-he_can_only_hold_her-ukp.mp3;0
[17:21:46.2111] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\111-amy_winehouse-addicted-ukp.mp3;0
[17:21:46.2281] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\201-amy_winehouse-valerie-ukp.mp3;0
[17:21:46.2451] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\202-amy_winehouse-cupid_(deluxe_edition_version)-ukp.mp3;0
[17:21:46.2611] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\203-amy_winehouse-monkey_man-ukp.mp3;0
[17:21:46.2781] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\204-amy_winehouse-to_know_him_is_to_love_him_(napster_live)-ukp.mp3;0
[17:21:46.2941] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\205-amy_winehouse-hey_little_rich_girl_(ft._zalon_and_ade)-ukp.mp3;0
[17:21:46.3101] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\206-amy_winehouse-youre_wondering_now-ukp.mp3;0
[17:21:46.3271] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\207-amy_winehouse-some_unholy_war-ukp.mp3;0
[17:21:46.3441] Yatse2Api-XHT : COMMAND : AddToPlayList - E:\Liesbeth\MUZIEK\Amy Winehouse\208-amy_winehouse-love_is_a_losing_game_(original_demo)-ukp.mp3;0
[17:21:47.1121] Yatse2        : New Music Media : E:\Liesbeth\MUZIEK\Amy Winehouse\101-amy_winehouse-rehab-ukp.mp3
[17:21:47.1251] Yatse2        : GetRandomImagePath : no images in E:\Arthur\Downloads\Yatse\Yatse2-Alpha-Refresh\Yatse2\Cache\Music\Fanarts
[17:21:47.1781] Yatse2Api-XHT : COMMAND : FileExists - DefaultAlbumCover.png
[17:21:47.1791] Yatse2        : Missing skin image : \Interface\Default_MusicThumb.png
[17:21:47.1811] Yatse2DB      : Query : SELECT * FROM `AudioSongs` WHERE IdRemote = @idRemote AND (Path || FileName = @Filename OR FileName = @Filename );
[17:21:47.1811] Yatse2DB      : Param : @idRemote=1 , @Filename=E:\Liesbeth\MUZIEK\Amy Winehouse\101-amy_winehouse-rehab-ukp.mp3
[17:21:47.1871] Yatse2DB      : Query : SELECT * FROM `AudioArtists` WHERE IdRemote = @idRemote AND IdArtist = @idArtist ORDER BY Name;
[17:21:47.1871] Yatse2DB      : Param : @idRemote=1 , @idArtist=7
[17:21:47.1881] Yatse2        : Music starting : Switch to currently
[17:21:47.1881] Yatse2        : Show Grid : grd_Currently
[17:21:52.6234] Yatse2        : GetRandomImagePath : no images in E:\Arthur\Downloads\Yatse\Yatse2-Alpha-Refresh\Yatse2\Cache\Music\Fanarts
[17:21:54.7396] Yatse2        : Home Page : grd_Home
[17:21:54.7406] Yatse2        : Show Grid : grd_Home
Well the log is ok all file are correctly queued by yatse.
I need the XBMC log Smile since the problem seems to be on XBMC side.
Perhaps using a version that does not handle correctly the AddToPlaylist.
But please upload the file somewhere or use pastebin.com for logs it's much more useable Smile
Tolriq.
Quote:But please upload the file somewhere or use pastebin.com for logs it's much more useable
The log from XBMC:
(In pastebin Big Grin)
Link to pastebin
Hum the log is quite empty Smile
Did you activate debug mode in XBMC and start again the album play ? Smile
This time with debug information. Started Amy winehouse back to black album en skipped from the first to the second song and Number ones album from the beatles.
Link
  • 10
  • 11
  • 12(current)
  • 13
  • 14
  • 55
Yatse 2 : Open Source Media Center Remote Control App for Touch Screen5
