  • 33
  • 34
  • 35(current)
  • 36
  • 37
  • 55
Win Yatse 2 : Open Source Media Center Remote Control App for Touch Screen
Build 132 online.
Add support for last Eden nightlies. If you use Eden and Yatse you must update both.
This build is not 100% optimized but is working. Next update will arrive with final Eden build (or sooner if there's too many bug :p)
Hi Tolriq.
Any ETA on resolving open issues? especially issue 31 http://yatse.leetzone.org/redmine/issues/31
Are any new features planed to be added?
Well as said my life is quite complicated right now Smile
Since i have some users i fell the need to support new XBMC version, but i can"t do much more.
I'll try to correct this issue in the build i'll publish when final Eden is out.
I just started using Yatse today, and I really like what I see so far. My goal is to use this program as a central control for as many as 3 or 4 XBMC installs.
My config:
Windows 7 Home Premium
XBMC 10.1
Running Yatse on same PC as XBMC (for now)
Primary display: 1080p LCD
Secondary display: 7" LCD Touchscreen @ 800x600
I have a quick question. When I drag my finger across the touchscreen, I very often move the entire Yatse screen instead of acting upon items in the program itself. Is this expected behavior or can a setting be changed to fix this?
Hello, Glad you like Yatse.
For your problem it seems you have checked the settings : Mouse mode in display.
Just uncheck and yatse won't move. This settings is more for people who want's to try yatse with mouse on a netbook and be able to move the screen around.
Tolriq Wrote:Hello, Glad you like Yatse.
That fixed it. Thanks!
Back again for another question.
My movie collection consists of mostly a straight rips from DVDs. When the movies start, they get to the DVD menu and get "stuck". There doesn't appear to be a way to navigate the menu to start the main movie.
Any ideas?
Well i do not use dvd rips, but if you have correctly activate eventserver in XBMC, you can click on the top right icon in yatse to get a mini remote to move in menu and start the movie.
New build 134.
Weather is back and corrected ticket #31 for dhead Smile
Tolriq Wrote:New build 134.
Great news.Smile
Works like charm.
Weather is still not working for me. Any ideas?
Thanks,
Kevin
What is not working ?
You can't select your city ? No images ? Nothing works ?
Can you please put yatse in debug and trace mode and upload the logs ?
Tolriq Wrote:What is not working ?
Not much to see, but here it is:
http://pastebin.com/mbjcUCLa
I am able to enter my city and a city code is identified. The weather screen stays blank, however.
Hum ok seems i made a little mistakes with units with the api change.
Can you change to °C and see if it works.
If yes i'll release a new build to correct this.
Thanks for the report.
Tolriq Wrote:Hum ok seems i made a little mistakes with units with the api change.
Changing to Celsius worked.
  • 33
  • 34
  • 35(current)
  • 36
  • 37
  • 55
Yatse 2 : Open Source Media Center Remote Control App for Touch Screen5
