I'm going to hold off on my mod, just to see what you have in store...
Hitcher
Team-Kodi Member
Add-on compatible version now ready.
See first port for install instructions.
Hitcher
Team-Kodi Member
Copy and paste - corrected now.
Hitcher
Team-Kodi Member
Opps, just realised I left debugging on - re-uploading.
Just FYI. Ideally there should be no need to extract the archive manually. Just select install from .zip and browse to the previously downloaded file and you're done.
Always read the
online manual (wiki),
FAQ (wiki) and search the forum before posting.
Do not PM or e-mail Team-Kodi members directly asking for support. Read/follow the
forum rules (wiki).
Please read the pages on
troubleshooting (wiki) and
bug reporting (wiki) before reporting issues.
Hitcher
Team-Kodi Member
Forgot about that, thanks.
Hitcher
Team-Kodi Member
I can't upload the fixed version yet so if you've downloaded you'll need to edit the addon.xml and change debug to false.
I've added your addon, but in the repo I'm only seeing Alaska Revisited not the original. Any ideas?
Hitcher
Team-Kodi Member
Try 'Force Refresh' on my repo from the context menu.
Hitcher
Team-Kodi Member
Thanks, it's all worth it when others like your work.
Installed...great skin ..thanks for updating it
Yeah thanks alot Hitcher, really!
Your work is stunning as always.
