2013-09-05, 16:59
(2013-09-05, 04:15)madivad Wrote:(2013-09-05, 02:37)xDetoursx Wrote: Not sure if this has been covered yet or not, but I didn't have time to search 347 pages.
Problem is solved..at least for me. If you go to Youtube and login, there's a little gray drop down arrow up at the top right. Click that and you can see a new email address that the account is associated with under the login name.
Thanks xDetoursx, that was the push I needed. I have spent the last hour going over my google account and found that to be half my problem. I still haven't got application specific password working for xbmc (it insists on my main password), but the biggest GOTCHYA I had was xbmc uses my email address as my account for youtube and I (by default) use a username. I never wanted my email address up the top there. Now that I told youtube to use my email address, I can see favourites and playlists in xbmc (although they're only what I've setup right now).
I need to work on a way to have xbmc only use my user login (which youtube seems adamant can't be done anymore). I'm not sure if it matters at the moment or not. I'm still looking into it. I have my domain setup through google apps and it was a real PITA getting 2 step verification process activated. Thanks again for your screen grabs, although very different to what I have on my side, it did get me going in the right directions. Ciao!
Hello,
I'm having the save problem, plugin won't recognize my channel with username, and reverting youtube to my email address it works but won't load all the history from my username channel, is there any way to get this working, preferably with youtube's channel username because every time I post on youtube with my email address user it asks if I want to create a channel and i want to keep using my channel at youtube.
please Dev's, make plugin compatible with channel username.
