19 Nov 2019 - TVDB are still in the process of fixing a number of bugs that have broken the TVDB scraper and any add-on that relies on TVDB data. TVDB are still working to rectify the problems.
  • 5(current)
  • 6
  • 7
  • 315
  Thread Closed
Release [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
#61
Just have to thank you for this plugin, it's working great.
#62
feerlessleadr Wrote:i think this may have something to do with my problem. I have a '\' in my password. Could that be the reason that I can't login and the script is failing?
Possibly, try with version 0.9.6, and if it still fails give us a new debug log.
#63
Added version 0.9.6
- Fixed potential crash in Recommended core function
- Fixed crash in Feeds when a video was marked private
- Added more debug to rtmp calls
- Added more debug to login
- Fixed pageination in "Most Recent" and "Recently Featured"
- Always have enabled debug.
http://code.google.com/p/youtubexbmc/downloads/list
Anyone with problems with either login or rtmp, please try 0.9.6 and give me the debug log.
I know i keep asking for this, but that's the only way to get to the root of this issue.
#64
Unable to log in. http://pastebin.com/tG9GXrN6
#65
Redneck Wrote:Unable to log in. http://pastebin.com/tG9GXrN6
Please try with 0.9.6
#66
Regarding the login problem.
I just tried on windows, and it finally triggered for me.
My backup code in the login function triggered, and it logged in.
That was with 0.9.6
#67
TobiasTheCommie Wrote:Please try with 0.9.6
I'm pretty sure I didHuh But just to make sure I uninstalled, re-downloaded, installed.
http://pastebin.com/2fFykbjg
#68
Redneck Wrote:I'm pretty sure I didHuh But just to make sure I uninstalled, re-downloaded, installed.
That's weird, all your log says is
Quote:08:56:16 T:816 M:1106243584 NOTICE: YouTube login failed, hit ioerror except: <urllib2.URLError instance at 0x0A3A4A58>
whereas my log says
Quote:15:12:13 T:3924 M:1354264576 NOTICE: YouTube-0.9.6 login
15:12:13 T:3924 M:1354264576 NOTICE: YouTube-0.9.6 login not using ip address
15:12:13 T:3924 M:1354252288 NOTICE: YouTube-0.9.6 login data username <type 'str'> - Password <type 'str'>
15:12:13 T:3924 M:1354252288 NOTICE: YouTube-0.9.6 login connect
15:12:23 T:3924 M:1346379776 NOTICE: YouTube-0.9.6 login failed, hit ioerror except2: : <urllib2.URLError instance at 0x0952CA58>
15:12:23 T:3924 M:1346375680 NOTICE: ERROR: YouTubeCore::login (117) - <urlopen error (8, 'EOF occurred in violation of protocol')>
15:12:23 T:3924 M:1346375680 NOTICE: CLASS:
15:12:23 T:3924 M:1346375680 NOTICE: URLError
15:12:23 T:3924 M:1346375680 NOTICE: ID:
15:12:23 T:3924 M:1346375680 NOTICE: 156420696
15:12:23 T:3924 M:1346375680 NOTICE: TYPE:
15:12:23 T:3924 M:1346375680 NOTICE: <type 'instance'>
15:12:23 T:3924 M:1346375680 NOTICE: VALUE:
15:12:23 T:3924 M:1346375680 NOTICE: <urllib2.URLError instance at 0x0952CA58>
15:12:23 T:3924 M:1346375680 NOTICE: CALLABLE:
15:12:23 T:3924 M:1346375680 NOTICE: No
15:12:23 T:3924 M:1346375680 NOTICE: None
15:12:23 T:3924 M:1346375680 NOTICE: YouTube-0.9.6 login
15:12:23 T:3924 M:1346211840 NOTICE: YouTube-0.9.6 login ip : '66.102.13.147'
15:12:23 T:3924 M:1346211840 NOTICE: YouTube-0.9.6 login data username <type 'str'> - Password <type 'str'>
15:12:23 T:3924 M:1346211840 NOTICE: YouTube-0.9.6 login connect
15:12:24 T:3924 M:1346158592 NOTICE: YouTube-0.9.6 login: ['Content-Type: text/plain\r\n', 'Content-Length: 280\r\n', 'Date: Wed, 25 Aug 2010 13:12:27 GMT\r\n', 'Expires: Wed, 25 Aug 2010 13:12:27 GMT\r\n', 'Cache-Control: private, max-age=0\r\n', 'X-Content-Type-Options: nosniff\r\n', 'X-Frame-Options: SAMEORIGIN\r\n', 'X-XSS-Protection: 1; mode=block\r\n', 'Server: GSE\r\n', 'Connection: close\r\n']
15:12:24 T:3924 M:1346158592 NOTICE: YouTube-0.9.6 login read
15:12:24 T:3924 M:1346158592 NOTICE: YouTube-0.9.6 login close
15:12:24 T:3924 M:1346158592 NOTICE: YouTube-0.9.6 login regex
15:12:24 T:3924 M:1346158592 NOTICE: YouTube-0.9.6 login result : 1
15:12:24 T:3924 M:1346154496 NOTICE: YouTube-0.9.6 _httpLogin
15:12:26 T:3924 M:1346273280 NOTICE: YouTube-0.9.6 _httpLogin: Logged in with login_info cookie: a54ab36354a0fe37c643a616c3b671a9c3kAAAB7IjEiOiAxLCAiMyI6IDMxMTAzNTQ4NCwgIjIiOiAieWVfTF9IcGJmY0xLZGxZVWFpaWlLdz09IiwgIjUiOiA1NjQwNDk0NTY3MzAzNjcsICI0IjogIkdBSUEiLCAiNyI6IDEyODI3NDE5NDgsICI2IjogZmFsc2V9
15:12:26 T:3924 M:1346273280 NOTICE: YouTube-0.9.6 login done: TobiasTheViking
http://pastebin.ca/1925093
#69
Pretty much the same thing from my ubuntu rig.
http://pastebin.com/7hPigZEJ
#70
Redneck Wrote:Pretty much the same thing from my ubuntu rig.
Are you sure your ubuntu rig is running 0.9.6?
I can see logging on it. It just says "YouTube" and not "YouTube-0.9.6" as it should.
Quote:09:23:45 T:2884377456 M:631562240 NOTICE: YouTube login
09:23:45 T:2884377456 M:631562240 NOTICE: YouTube login data username <type 'str'> - Password <type 'str'>
09:23:45 T:2884377456 M:631562240 NOTICE: YouTube login connect
09:23:45 T:2884377456 M:631562240 NOTICE: YouTube login failed, hit ioerror except: [0] <urllib2.URLError instance at 0xb4d32d4>
#71
TobiasTheCommie Wrote:Are you sure your ubuntu rig is running 0.9.6?
I installed from the same zip that I re-downloaded before.
#72
Humm.. this is the changelog.txt
[b]Errata[/b]
- Plugin can't play next item in queue if a modal keyboard is displayed ( XBMC bug )
  - Fixed in svn revision 33055, will be merged with dharma when a reviewer signs off.
[b]Version 0.9.4[/b]
- Added refinements of searches support
- Added queue folder support
- Fixed RTMP support
- Implemented release disable support for RTMP
- Added try/except to _extractVariables
- Hopefully improved login debugging.
[b]Version 0.9.3[/b]
- Added better errorhandling of videos youtube deny access too
- Actually enable debugging
[b]Version 0.9.2[/b]
- Added debug to login
- Fixed playback of non playable item (settings)
[b]Version 0.9.1[/b]
- After showing the settings window on the first run it didn't log in.
- Improved error messages related to login.
- Added some more error handling.
[b]Version 0.9[/b]
- Cleanup of listFeedFolder
- Cleanup of listUserFolder
- Added Viewed and Downloaded overlay to video items.[CODE][/CODE]
#73
wtf, i downloaded it from the the homepage on my windows machine, didn't svn or anything.
Just a moment.
#74
Ok, just downloaded it from http://code.google.com/p/youtubexbmc/downloads/list and the code was correct (changelog said 0.9.6)
Checked the local zip file, also says 0.9.6.
I just uploaded it to http://rapidshare.com/files/415074640/pl...e.beta.zip
as well
Just downloaded from rapidshare as well and changelog said 0.9.6
#75
Downloaded from Rapidshare look like the right version.
ubuntu http://pastebin.com/vcNviyKG
windows http://pastebin.com/De7SMZrH
  • 5(current)
  • 6
  • 7
  • 315
  Thread Closed
  • 28 Vote(s) - 4.14 Average
[depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only4.1428
