pike
Team Kodi Admin
but does it work for youtube ? Test with stuff that we know work please, I have never seen that MU stuff...
Oh, I will test it. I saw you linked to this thread in the icefilms thread, so I figured it should work universally.
Just so you know, its definitely not working with streams OTHER than youtube. I've tried the Sesame Street addon, and the Canada On Demand addon. When you pause, it's just paused, and it stops downloading pretty much right away.
I'll test youtube when I have a moment and report back.
haha, bingo. I didn't have the <advancedsettings> tags in there. Now its working well, thanks! Makes things much more useable!
Is it possible that my MegaUpload user account info is not being used somehow? I do get the 'log in successful' message, and I have a premium account. But my slow download speeds have me baffled...
2011-06-02, 19:48
(This post was last modified: 2011-06-02, 19:50 by vinistois.)
the nightlies are built for you, nightly, from current git head. Git contains the source Code. From the source, windows/linux/live builds can be built.
As of early May, all the nightly builds have this functionality.
So you can build your own from git (called building from source), or just download and install a nightly pre-compiled version.
Create a file in your userdata dir called advancedsettings.xml
the file has to contain this text:
<advancedsettings>
<network>
<cachemembuffersize>0</cachemembuffersize>
</network>
</advancedsettings>
easiest way to create this xml file is to just copy one of the other xml files in that dir, rename it, then open it and paste in this text (deleting the rest of what was in there). Save the file, reboot xbmc, and bobs your uncle.
Logins stopped working completely after update to 2.04, but works like charm in 2.03.
I wonder... how to disable automatic updates?
Hi HenrikDK
I am fine with 2.03 for now. If 2.05 (or whatever next version it will be) will not work, I'll open the ticket.
Cheers
PS: Platfrom is Win7. You could've guessed=)
