  • 13
  • 14
  • 15
  • 16
  • 17(current)
[RELEASE] Aeon Showmix 2.5 Dharma
Hey Zombie,
I asked this earlier in the thread, but it was probably overlooked.
how do you change the default layout to something other than multiplex?
I suggest you check out the Icefilms addon not only to see what I mean, but also because its amazing. It is extremely folder heavy, so browsing through the layers is very cumbersome in multiplex. Any way I can maybe change the default to just List, and then select Multiplex for the specific folders that can benefit from the view?
Sorry if theres a simple switch somewhere, but Ive been through every settings page a dozen times and cant figure it out.
dangerFlakes Wrote:Hey Zombie,
hey there where do i find this addon.
i have changed the default to list in next release hope it will help but if still loading multiplex view in next release let me know and i will look into a fix
You rock, man.
Get the add-on here.
Many thanks
Will anoobies mods work with this skin?
Particularly this:
Using this file:
Mod 3
And discussed in this thread:
http://forum.xbmc.org/showthread.php?tid...oobie+mod3
I am currently using this skin in my mediacenter, but would like to upgrade to dharma. At the same time I would hate to loose this excellent skin mod.
Is there by chance another current skin/mod that resembles this, with coverflow in the bottom and video window in the middle, with this cool 3D look?
Regards,
Ole Martin
oleroc Wrote:Will anoobies mods work with this skin?
Particularly this:
Using this file:
Mod 3
Regards,
Ole Martin
Hey there Ole Martin Dont think this view will be added to showmix any time soon but you never know i have however added this view to aeon lite and have coded about 50% of the code already once i add it to Lite i will look at showmix maybe its a S#!t load of code to be done to add a view in showmix
Also to anyone who comes to this thread we have a new showmix thread that can be found here
THIS THREAD IS DEAD!!!!!
  • 13
  • 14
  • 15
  • 16
  • 17(current)
[RELEASE] Aeon Showmix 2.5 Dharma2
