2010-10-25, 18:20
xbmcFreak Dharma Beta3
Zotac IonItx-LE mobo
xbmc svn:
so my problem is as follows... I have S3 sleep working I can suspend to sleep and wake using my remote. I have WOL working so from my unRaid sever I can send the magic packet to HTPC waking it from S3 Sleep.
I am able to connect to htpc using putty, but when I try and access web browser I do not get connection. xbmc gui tells me problem with my dns sever.
I have tried doingbut it doesn't solve my problem
here is what my dns sever file looks like
and here is my network config file
I tried changing my dns sever to 192.168.2.1 my routers IP it doesn't work after a network restart.
but connecting via putty works so something is strange here as my ifconfig has no errors or oddities
here is output from ethtool eth0
-=Jason=-
xbmc svn:
xbmc@XBMCLive:~$ apt-cache policy xbmc
xbmc:
Installed: 2:10.00~svn34731-lucid1
Candidate: 2:10.00~svn34731-lucid1
Version table:
*** 2:10.00~svn34731-lucid1 0
500 http://ppa.launchpad.net/team-xbmc-svn/ppa/ubuntu/ lucid/main Packages
100 /var/lib/dpkg/status
1:9.11-lucid3 0
500 http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ lucid/main Packages
I have tried doing
sudo /etc/init.d/networking restart
xbmc@XBMCLive:/usr/share/xbmc/system/keymaps$ cat /etc/resolv.conf
domain Belkin
nameserver 205.171.2.25
nameserver 205.171.3.25
xbmc@XBMCLive:/usr/share/xbmc/system/keymaps$ cat /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet static
address 192.168.2.5
netmask 255.255.255.0
gateway 192.168.2.1
xbmc@XBMCLive:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:01:2e:2c:cd:7a
inet addr:192.168.2.5 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::201:2eff:fe2c:cd7a/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:7414 errors:0 dropped:0 overruns:0 frame:0
TX packets:7155 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1048951 (1.0 MB) TX bytes:1596947 (1.5 MB)
Interrupt:21 Base address:0xe000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:25 errors:0 dropped:0 overruns:0 frame:0
TX packets:25 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1520 (1.5 KB) TX bytes:1520 (1.5 KB)
xbmc@XBMCLive:~$ sudo ethtool eth0
Settings for eth0:
Supported ports: [ MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Link partner advertised link modes: Not reported
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: No
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 3
Transceiver: external
Auto-negotiation: on
Supports Wake-on: g
Wake-on: g
Link detected: yes
-=Jason=-
