2010-11-01, 10:52
Hi guys,
A short guide on how to get the remote & audio to work after a XBMC Live Dharma Beta 4 install on your ASRock ION 330HT within 5 minutes:
SSH into your asrock and execute the following commands after having installed XBMC Live to your HDD:
1. Remote:
2. Audio:
In XBMC :
- use Audio Mixer add-on (Progams > Program Add-ons > Audio-mixer) and un-mute 'IEC958,1'
- Change both audio output devices (System > Settings > System> Audi Output)to "hdmi"
For reference (should the pastebin links timeout at some point) (credit goes to Reolio):
/etc/asound.conf:
/usr/share/alsa/cards/HDA-Intel.conf
Have fun
1. Remote:
wget "http://europe.asrock.com/downloadsite/drivers/Nettop/Ubuntu/IR(10.04)2.6.32-25.zip"
unzip IR\(10.04\)2.6.32-25.zip
sudo dpkg -i lirc-nct677x-1.0.4-ubuntu10.04_kernel2.6.32-25.deb
2. Audio:
sudo wget http://pastebin.com/download.php?i=f5f9654bb -O /etc/asound.conf
sudo wget http://pastebin.com/download.php?i=f2e38265 -O /usr/share/alsa/cards/HDA-Intel.conf
In XBMC :
/etc/asound.conf:
pcm.!hdmi-remap {
type asym
playback.pcm {
type plug
slave.pcm "remap-surround71"
pcm.!remap-surround71 {
type route
slave.pcm "hw:0,3"
ttable {
0.0= 1
1.1= 1
2.4= 1
3.5= 1
4.2= 1
5.3= 1
6.6= 1
7.7= 1
# Configuration for the Intel HD audio (ICH6/ICH7)
<confdir:pcm/front.conf>
HDA-Intel.pcm.front.0 {
@args [ CARD ]
@args.CARD {
type string
type softvol
control {
name "PCM Playback Volume"
card $CARD
# default with dmix+softvol & dsnoop
HDA-Intel.pcm.default {
@args [ CARD ]
@args.CARD {
type string
type asym
playback.pcm {
type plug
slave.pcm {
type softvol
control {
card $CARD
capture.pcm {
type plug
slave.pcm {
type softvol
slave.pcm {
@func concat
strings [ "dsnoop:" $CARD ]
control {
name "Digital Capture Volume"
card $CARD
min_dB -30.0
max_dB 30.0
resolution 121
# to avoid possible phase inversions with digital mics
route_policy copy
hint.device 0
<confdir:pcm/surround40.conf>
<confdir:pcm/surround41.conf>
<confdir:pcm/surround50.conf>
<confdir:pcm/surround51.conf>
<confdir:pcm/surround71.conf>
HDA-Intel.pcm.surround40.0 cards.HDA-Intel.pcm.front.0
HDA-Intel.pcm.surround51.0 cards.HDA-Intel.pcm.front.0
HDA-Intel.pcm.surround71.0 cards.HDA-Intel.pcm.front.0
<confdir:pcm/iec958.conf>
HDA-Intel.pcm.iec958.0 {
@args [ CARD AES0 AES1 AES2 AES3 ]
@args.CARD {
type string
@args.AES0 {
type integer
@args.AES1 {
type integer
@args.AES2 {
type integer
@args.AES3 {
type integer
type asym
playback.pcm {
type hooks
slave.pcm {
type hw
card $CARD
device 1
hooks.0 {
type ctl_elems
hook_args [
name "IEC958 Playback Default"
lock true
preserve true
value [ $AES0 $AES1 $AES2 $AES3 ]
name "IEC958 Playback Switch"
lock true
preserve true
value true
capture.pcm {
type hooks
slave.pcm {
type hw
card $CARD
device 1
hooks.0 {
type ctl_elems
hook_args [
name "IEC958 Capture Switch"
lock true
preserve true
value true
hint.device 1
<confdir:pcm/hdmi.conf>
HDA-Intel.pcm.hdmi.0 {
@args.CARD {
type string
@args.AES0 {
type integer
@args.AES1 {
type integer
@args.AES2 {
type integer
@args.AES3 {
type integer
type hooks
slave.pcm {
type plug
hooks.0 {
type ctl_elems
hook_args [
lock true
preserve true
lock true
preserve true
value true
hint.device 3
<confdir:pcm/modem.conf>
HDA-Intel.pcm.modem.0 {
@args [ CARD ]
@args.CARD {
type string
type hw
card $CARD
device 6
hint.show off
Have fun
