  • 6
  • 7(current)
  • 8
  • 9
  • 17
SLik - skin
#91
It's unbelievable, this skin is so fast!
Cheers
ubuntuf4n
Cheers Jezz_X my new default Revo skin.
OK I don't like the trailing white box when viewing Posters in Movies so I fixed it.
just makes it look more consistent.
ViewsVideoLibrary.xml
PHP Code:
                <control type="image">
posx>2</posx>
posy>0</posy>
width>214</width>
height>310</height>
aspectratio>stretch</aspectratio>
texture border="5">ThumbNF.png</texture>
animation reversible="false" effect="fade" start="100" end="0" delay="200" time="10">focus</animation>
animation reversible="false" effect="zoom" end="2,0,214,310" start="-8,-10,234,330" time="200">unfocus</animation>
control>
posx>2</posx>
posy>0</posy>
width>214</width>
height>310</height>
texture border="5">ThumbFO.png</texture>
animation reversible="false" effect="zoom" start="2,0,214,310" end="-8,-10,234,330" time="200">focus</animation>
animation reversible="false" effect="fade" start="100" end="0" time="10">unfocus</animation>
control
PHP Code:
posx>2</posx>
posy>310</posy>
width>214</width>
height>310</height>
texture background="true" flipy="true" diffuse="diffuse_mirror.png">ThumbNF.png</texture>
animation reversible="false" effect="fade" start="100" end="0" time="10">focus</animation>
animation reversible="false" effect="zoom" end="2,310,214,310" start="-8,320,234,330" time="200">unfocus</animation>
control>
posx>2</posx>
posy>310</posy>
width>214</width>
height>310</height>
texture background="true" flipy="true" diffuse="diffuse_mirror.png">ThumbFO.png</texture>
animation reversible="false" effect="zoom" start="2,310,214,310" end="-8,320,234,330" time="200">focus</animation>
control
Also the last view for TV Shows doesn't have a view name.
The view name is there but it isn't showing.
  • Intel NUC Kit DN2820FYKH
  • Crucial DDR3L SO-DIMM 4GB
  • SanDisk ReadyCache 32GB SSD
  • Microsoft MCE model 1039 RC6 remote
Rocky5 Wrote:Cheers Jezz_X my new default Revo skin.
Thanks Rocky added the code and fixed the label
Jezz_X Wrote:Thanks Rocky added the code and fixed the label
NP, you may want to hide Logo off from the login screen Big Grin or grey it out
Jezz_X Wrote:only updates is Ive been working on the pvr parts about 90% done on them now once done I will commit it and build a working pvr release it (hopefully within a week) then back to the main skin tweaking
Fantastic!
Rocky5 Wrote:NP, you may want to hide Logo off from the login screen Big Grin or grey it out
Thanks keep em coming if you find then Smile
avus m3 Wrote:Fantastic!
You can find the pvr version here btw if you want it http://forum.xbmc.org/showthread.php?tid=85831
Jezz_X, I really like the skin for its simplicity, not to mention it is lightning fast.
I have a problem that you might be able to shed some light on, I may be [email protected]@king something.
When I go into the file manager, I can not get to the parent folders. It lists a few random directories, but the double dot .. parent directory is missing. It is in the other selections (Music, Videos, Pictures, etc.) but not in the File Manager screen.
your right but its an xbmc issue not a skin one so all skins will have that issue I would assume
Just have to pitch in and say I love the skin so far, very well done and seems way more polished than an alpha.
2 quick questions though:
1. Is it possible to show the current time (as in time of day) during playback?
2. Will the timer shutdown option be added to the shutdown options?
Can't wait to get my hand on a tv-card and check out the PVR.
Cheers,
/Shadowsoul
1 the current svn version already has this
2) yeah I will look into adding that to the home shut down menu
Jezz_X Wrote:your right but its an xbmc issue not a skin one so all skins will have that issue I would assume
Of course your right, should have looked at another skin. I just had to enter add source to get to the other folders. Doh!
Great work! Exactly what you said it focuses on that's what it does! Very smooth and super fast! Thanks a lot!
Nice one Jezz, fast and brings all I want. My default skin now.
I think the RSS feed would look nicer if it looked like it went behind the RSS feed logo instead of just ending before it.
even <posx>55 or 50
  • 6
  • 7(current)
  • 8
  • 9
  • 17
  • 3 Vote(s) - 5 Average
SLik - skin53
