hmm intresting i am not too sure, Best of luck thoe with ubuntu.
2010-12-19, 01:15
(This post was last modified: 2010-12-19, 01:29 by vonb3ta.)
ok so I ran the safeboot and get cpufreq kernel modules [fail]
Starting remote control daemon(s): LIRC (hangs here)
BUG: soft lockop - CPU#0 stuck for 61s!
Its gotta be something with this. I will do some more research but I am pretty set on getting this to work with the Live CD
-Update
It only does this when my external sound card is connected
I see the same thing on my Revo with V10.00 . cpufreq modules fail at boot and then it hangs (no external sound card though).
Anyone any ideas?
Did anyone manage to solve this?
I just got myself a 5.1 speaker set which require 6 phono inputs (not optical) so got myself a small usb soundcard with the right outputs. Now when I try to boot my Revo R3610 with Live installation 10.1 it hangs on bootup.
Safetboot gives the "CPU#0 stuck for 61s!" error too.
Patch p4-clockmod module using this script, and reboot.
#/bin/sh
kv=$( uname -a | awk '{ print $3 }')
module="/lib/modules/$kv/kernel/drivers/cpufreq/p4-clockmod.ko"
if [ ! -e "$module" ] ; then
echo "Module $module not found"
fi
echo "Search pattern"
l=$( xxd -c 1 ${module} | awk '{ i++; a=b; b=c; c=d ; d=$2; if (a == "81" && b == "96" && c == "98" && d == "00") print i-3; }')
if [ "$?" != "0" ] ; then
exit 1
fi
if [ -z "$l" ] ; then
echo "Pattern not found"
exit 1
fi
xxd -c 1 $module | awk -v l=$l '{ i++; if (i == l) { print $1 " 40 ." } else if (i == l+1) { print $1 " 42 ." } else if (i == l+2) { print $1 " 0f ." } else { print $0}}' > ${module}.hex
exit 1
fi
if [ ! -e "${module}.bak" ] ; then
echo "Create backup ${module}.bak"
mv $module ${module}.bak || exit 1
fi
xxd -c 1 -r ${module}.hex ${module}
cat ${module}.bak > ${module}
exit 1
fi
